Old 04-25-2010, 01:38 PM   #601
datsunnazi
datsunnazi's Avatar
datsunnazi is an unknown quantity at this point
Send a message via MSN to datsunnazi
Re: RB FAQ
Originally Posted by Spitfire8o5
Anyone know what replacement alternator I could use for my rb20det s13? Or would I have to look for an actual skyline alternator?
Stock S13 alternator and then cut the second hole off of the tensioner arm and bolt it all back on.
datsunnazi is offline   Reply With Quote
Old 04-25-2010, 01:59 PM   #602
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
or you can buy my alternator kit that lets you use a Nissan Quest alternator 130amps of power!
Review Thread
bardabe is offline   Reply With Quote
Old 04-25-2010, 10:31 PM   #603
Spitfire8o5
Spitfire8o5's Avatar
Spitfire8o5 is an unknown quantity at this point
Originally Posted by eklips3 View Post
save yourself the trouble of finding one. go to an alternator shop in your area and get them to rebuild it. it will be cheaper in the end rather then buying a whole new one.
dont know why i never thought of that.. local shop down the street! thanks
Spitfire8o5 is offline   Reply With Quote
Old 04-28-2010, 07:05 PM   #604
derek king
derek king's Avatar
NEED help
s1 Rb25
greddy intake manifold
front mount
stock turbo/boost
downpipe back exhaust
Since I have had the car the Car idles high sometimes and just wont go under 1500 other times it idles at 800 it sometime changes from stoplight to stoplight. BUT
Main problem is recently I was going on a 3 road trip and gowing down the highway I would roll into throttle and the car would just choke out on itself like it was completely flooding of fuel. So I would quick shut the key off and coast with it in gear for about 3-5 seconds and turn key back on and then SHAZAM i could roll into throttle and it rapes like normal no issues at all. BUT then 15 min later the same issue would happen.
Now this consistantly happens all the time.
= stuck injector?
= I also have heard that the stock ecu runs very rich factory and with the intake manifold it could be overfueling from all the extra air the maf is reading?
IG DearDerekKing
Old 04-28-2010, 07:31 PM   #605
DJDANGER24
DJDANGER24's Avatar
DJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond reputeDJDANGER24 has a reputation beyond repute
Send a message via AIM to DJDANGER24 Send a message via MSN to DJDANGER24 Send a message via Yahoo to DJDANGER24
do you have the consult plug installed ? if not, i would recommend installing it and just to be on the safe side, replace your O2 sensor, it may be bad.
Built RB25 - RB The World - Vertex Everything @RBVertexRidge
DJDANGER24 is offline   Reply With Quote
Old 04-28-2010, 07:47 PM   #606
derek king
derek king's Avatar
I actually do have a consult but no serial cable to hook up to the computer. What all will the consult tell me that could help this problem?
IG DearDerekKing
Old 04-28-2010, 08:39 PM   #607
DJDANGER24
DJDANGER24's Avatar
what your O2 sensor is reading, it may be faulty hence cutting you out when you get on it. same thing was happening to my brothers MR2 and my RB25, swapped out the O2 for a new one and the problem went away.
Old 04-28-2010, 09:44 PM   #608
!!chuy!!
!!chuy!!'s Avatar
!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore
RB rb25 ecu speed signal wire?
Does anyone know which wire is the speed signal wire on my rb25 s1 ecu?
!!chuy!! is offline   Reply With Quote
Old 04-28-2010, 09:55 PM   #609
GSXRJJordan
GSXRJJordan's Avatar
I wouldn't bet on o2 sensor, but it's certainly a possibility. What fuel pump are you running, and how old is it? Ever have slow starts?
Old 04-28-2010, 10:07 PM   #610
mr_chingon
mr_chingon's Avatar
mr_chingon is an unknown quantity at this point
bad injector o-ring
mr_chingon is offline   Reply With Quote
Old 05-15-2010, 03:50 PM   #611
Spitfire8o5
I have an 89 se 240 coupe w/rb20det w/ factory HUD and digital cluster but nothing works except for the temp. I was wondering if I need to modify anything or get a specific cluster.. I haven't been able to try another cluster because all of my friends have the regular cluster.. If anyone could help it would be appreciated.. I would like to know how fast I'm going, and how much gas I have at least haha
thanks in advance..
Roger
.TrackMafia.
Old 05-25-2010, 04:12 PM   #612
roboticnissan
roboticnissan's Avatar
I've got some issues with my rb20. Where is there a knowledgable shop in the IE or socal area?
roboticnissan is offline   Reply With Quote
Old 05-25-2010, 04:48 PM   #613
GSXRJJordan
Yes, there are quite a few people that can help you out... since you said IE, I recommend Bardabe (a contributing member here and on Socal-drift), he's in Perris.
Old 05-25-2010, 04:56 PM   #614
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
double true...
theres others you could take it to....to get it done...but if you want it done right...Bardabe is ur bitch...err, man to go to...lol
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 05-26-2010, 03:11 PM   #615
roboticnissan
Thanks guys a lot I read his review thread as well. Tons of good stuff. PM SENT
Old 05-27-2010, 08:37 AM   #616
battle_240sx
battle_240sx's Avatar
battle_240sx is an unknown quantity at this point
rb20 ecu
i want to get a rom tune for my rb20 can someone post some links for me. also i was looking at using the stock ex mani and weldong a wg to it for my 60-1 has anyone did that with good results??
thank you
battle_240sx is offline   Reply With Quote
Old 06-07-2010, 04:29 PM   #617
roboticnissan
Has anyone done a ls coilpack wrietup for rb engines? I found a few dead links and some ppl on S AU that have done it but no writeup. What's the general opinion of this conversion? I hear its much better as far as reliability on other fourums and I wanna do this to my rb20.
Old 06-07-2010, 04:51 PM   #618
roboticnissan
Does anyone know bardabe? He hasn't not returned my pm
Old 06-13-2010, 09:49 AM   #619
GTR_240SX
GTR_240SX's Avatar
GTR_240SX is an unknown quantity at this point
I'm starting the rb26 swap on my 1990 240... i got the engine, motor mounts, BOV, exhaust, intercooler... getting the mafs.. going to get the timing belt replaced. I know I need a radiator, anything else anyone can think of?
GTR_240SX is offline   Reply With Quote
Old 06-13-2010, 09:42 PM   #620
Backwoodsboy
Backwoodsboy is an unknown quantity at this point
seems like a good question area
i have an rb20 and for the life f me cannot get it to idle correctly, i have changed the tps with another used one, messed with cas, changed iacv, changed bov, checked for boost leaks...it will fire right up but then as it idles down it will just simply die...idk what to do...
Backwoodsboy is offline   Reply With Quote
Old 06-13-2010, 10:16 PM   #621
battle_240sx
i think every rb20 has an idle problem. i took the hose of my iacv and just use my throttle cable to adjust the idle. i just hold the gas to warm it up.
Old 06-14-2010, 07:39 AM   #622
Ghost240
Ghost240's Avatar
Ghost240 is an unknown quantity at this point
Nico forums, in the Rb section.
"Dare to bear the crown."
Illantic.com
Ghost240 is offline   Reply With Quote
Old 06-27-2010, 12:11 AM   #623
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
quick question here.
will a nismo tranny mount fit on a RB20 tranny ?
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
Old 06-30-2010, 08:59 PM   #624
eklips3
eklips3's Avatar
Can a S13 Nismo tranny mount fit on a RB20 tranny ?
Old 07-01-2010, 08:22 AM   #625
slideslidegnarslide
slideslidegnarslide is an unknown quantity at this point
how much power can you put out of a stock internal rb
slideslidegnarslide is offline   Reply With Quote
Old 07-01-2010, 01:47 PM   #626
eklips3
eklips3's Avatar
depends which one.
rb25 can take 500hp
rb20 can take maybe a little less
rb26 probably the same
so for each between 400-500 hp. Considering that the motor has good compression and is healthy.
Old 07-01-2010, 01:57 PM   #627
slideslidegnarslide
thank you rb25 here we come
Old 07-01-2010, 02:11 PM   #628
951's 330i
951's 330i is an unknown quantity at this point
Started a thread about this but im sure answer are probably here. Imma re read this thread but if someone can lmk it would be appreciated
Hey guys, exactly what the title says, what would be the part numbers here in the states for these three belts? (Sorry dont know which one is which)
These are part numbers that i got from NICO forums, but idk if they are the rights ones or not and if they can be ordered at like kragen or autozone? If they are, can someone tell me which one goes where? Thanks
Power steering: #k030334 gates belt
Alternator Belt: Gates K040335
A/C Belt: Gates K040378
-Bryan
951's 330i is offline   Reply With Quote
Old 07-01-2010, 07:06 PM   #629
Ghost240
Ghost240's Avatar
well how about you take the belts off and then take em to autozone or whatever and get em matched up. there ya go.
Illantic.com
Old 07-03-2010, 11:35 AM   #630
951's 330i
Yeah i pretty much am going to now
-Bryan
