#6661 |
hey guys i have a question. Just got wisefab front kit but have no clue how to adjust ackerman. I have the ackerman spacers but cant figure out where they go and how to put them and how to set them up
#6662 |
![]() Join Date: Jul 2011
Thanks for the answer. I see you suggest they work best with the S14 subframe. In my situation (SCCA Street Modified) I can't use conversion bushings for the S14 subframe on my S13. So between a S14 subframe with rubber bushings and a S13 subframe with solid bushings, what would be the best compromise?
My S13 SR Street Mod Build |
#6663 | |
![]() Join Date: Aug 2011
Also, considering they do not corner weight the cars (and they crash more often than regular race cars), using roll bars cause the suspension to preload and make the car unpredictable. So they don't use them. They counter roll with springs. |
#6664 | |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
GKTech |
#6666 |
![]() Join Date: Aug 2010
Trader Rating: (25)
![]() Feedback Score: 25 reviews
Has anyone actually measured these Megan Racing ball joints?
I see them everywhere and was just wondering if they just spaced the ball joint up. I know for the price and quality its better to go with something like Moonface. just wondering if anyone has actual proof. maybe a side by side picture
@andymcfly |
#6667 |
recommendations on a tie rod setup on an s13 with a 15mm extended lower control arm?
I had teins on my last car and I loved the spacer, but I'm not sure if they will work with the FLCA extension. thanks! |
#6668 | |
![]() Join Date: Apr 2004
It's faster than an S13 subframe, with much better traction on corner exit.
#6670 |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
If you only have 15mm extension on both sides, I would just suggest tein inners/outers or moog outers, and then pick yourself up a rack spacer.
DLG - DIRTYLOVE |
#6671 |
I would probably do the S14 subframe then with stiffer rubber bushings.
I wonder if you can get things to seat up with energy suspension urethane bushings. Might be enough compliance, might not.
#6672 | |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Highly doubt it. You'll push the center pins out and never get them back in when you're trying to put the subframe back in the car. |
#6673 |
You could drill the ES bushing to give it compliance in that direction. Then hopefully things are mostly locked up once it's on there.
#6674 |
And I don't mean make an offset bushing, I mean drill a compliance hole on the side of the bushing that is compressed, so that it can more easily get distorted into that shape.
#6676 |
There's also Jason Merritt's solution. Maybe that plus an ES "compliance" bushing would be best.
#6677 | |
EDIT: Just read on tein's site that only S14 outers will thread into the tein inners |
#6680 |
Well he has that added metal piece making the mount "solid", no?
#6682 |
Hmmm, guess I'm just forgetting how the stock bushings are, I went solid a while ago.
He refers to them as solid though: http://nissanroadracing.com/showpost...25&postcount=2
#6683 |
Trader Rating: (24)
he got 2nd at Nats last year and his car is built to the rules.
Lemme txt him and see if he'll reply here. Or you could send him a PM or something. |
#6684 |
![]() Join Date: Feb 2003
I effectively solid mounted my subrame pictured above by modifying the mounting hardware and not the bushings. I believe that some people deflect the inner metal spacer then weld it to the subrame off center.
. I'm OK with any sort of modification, but straight solid aluminum bushings are specifically not allowed. I think the intent of the rule is to prohibit relocating your subrame, and i think it should be re-worded. In the spirit of street modified I believe all popular modifications performed on popular street cars should be allowed. The intent of street mod is as a recruitment class for the younger generation that drive popular modified cars that don't fit into other street classes. Jason M |
#6686 | ||
Love your build btw and hope to see you at nationals someday when my car is done and I'm (hopefully) a better driver. I'm aiming for next year currently.
#6687 |
![]() Join Date: Jul 2009
anyone having good results with the gktech rear knuckles? Bummed out not getting to drive tomorrow. Had my rear suspension apart for 4 weeks now in anticipation for mines
#6690 |
I know, this does not answer your question at all, but you need to think about this before doing anything.
There are LOADS of mods to do that will give a better handling before that, and if you plan on competing, some classes don't allow this mod. Basically the s14 subframe has less antisquat, but antisquat is dynamic and you already remove some by lowering the car. I think the TDP rear suspension kit actually adds antisquat... Unless you already have quality suspensions, ball joints everywhere, front knuckle kit, sticky tyres and on and on (or are planning to), this really would be a waste of time. |
Tags |
anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
