Old 07-02-2017, 02:38 PM   #931
914Slide
914Slide's Avatar
914Slide can only hope to improve
I did finally get the car rolling do you guys know how and if or can i hook up the stock temp and tach on my dash from the lexus ecu ?
914Slide is offline   Reply With Quote
Old 07-10-2017, 08:05 AM   #932
1UZVillain
1UZVillain's Avatar
1UZVillain is an unknown quantity at this point
i saw somewhere that you can but will read funny, ill search for it
1UZVillain is offline   Reply With Quote
Old 07-23-2017, 02:21 PM   #933
OddyseusDSM
OddyseusDSM is an unknown quantity at this point
Possible any of you have a loose 1uz swap mount you could measure the height of?
I'm going to do a solid rubber mount, to which I'll post a "how to" thread. But id like to be in the ball park when I drop the engine.
OddyseusDSM is offline   Reply With Quote
Old 07-26-2017, 11:21 AM   #934
1UZVillain
1UZVillain's Avatar
sorry for the late response i was on vacation. I just measured my bret collins mounts and they are 5 inches in height (in the middle and both ends, consistently 5 inches)
excuse my misspellings
Old 07-26-2017, 11:22 AM   #935
1UZVillain
1UZVillain's Avatar
also is there any difference in the waterpumps and oil pumps between across the board for the 1uz including the vvti? i looked im getting conflicting answers. i need to order this part so i can move on
Old 07-26-2017, 11:43 AM   #936
OddyseusDSM
Hey thanks! I eyeballed a CAD representation and figured a hair under 5", awesome to have confirmation. I'm starting to think my idea is a little hokey but it'll work, just progressively getting simpler.
AFAIK the water pumps should be the same, timing kit is the same for my 05 tundra and a 00 gs400. Dunno about oil pumps. Cross reference rock auto?
Getting my fuel rails with return line in this week and doing the timing belt while I clean the garage to accept the car.
Old 07-26-2017, 11:50 AM   #937
1UZVillain
1UZVillain's Avatar
yup im ordering through rock auto. thanks for the response. where did you get your fuel rails?
Old 07-26-2017, 12:06 PM   #938
OddyseusDSM
2uzfe still used a return line while running a similar fuel pressure, figured its better than a vette/audi filter or modifying returnless. I'm gonna run the vvti 1uz in stockish trim for a while before I do anything to it. I might, have a 2nd rail setup coming.....but we'll see.
Old 07-26-2017, 12:13 PM   #939
1UZVillain
1UZVillain's Avatar
what brand would you use for the pumps? rockauto has gates, aisin and tmi(base on price not sure about that one)
Old 07-26-2017, 12:17 PM   #940
OddyseusDSM
Aisin was OE toyota, and comes with a Mitsubishi belt i think, havent recived mine yet but it was $162. I believe it was recommended on lextreme or clublexus.....one of the two.
Old 07-26-2017, 12:27 PM   #941
1UZVillain
1UZVillain's Avatar
okay cool, i also called the dealership they have it for 147 but without the belt part number 16100-59275-83 from toyota tundra should be same. but i get the whole kit on rockauto for the price you listed, think ill go that route
Old 07-26-2017, 12:51 PM   #942
OddyseusDSM
Aisin timing component kit TKT021, for anyone else that might read this. That comes with a new tensioner as well, its like $20 less without the tensioner.
Old 07-26-2017, 03:16 PM   #943
1UZVillain
1UZVillain's Avatar
wish there was a way to post pictures here easily. taking of ac compressor right now.
only issue im going to run into is taking off the crank bolt on a engine stand
Old 07-26-2017, 03:19 PM   #944
OddyseusDSM
Impact gun, the cheapy corded electric ones are great for doing suspension and whatnot. Not a true replacement for air but much cheaper and have their place.
Old 07-27-2017, 01:08 PM   #945
1UZVillain
1UZVillain's Avatar
using the collins kit for the ka, do you really have to back the transmission to only using 2 bolts? because of the strut bar? the driveshaft i got is shorter than my driveshaft shop 1 peice, reason i got it was for the lighter aluminum material.
my strut bar is off so can i still put it in the stock position and just use my stainless steel one?
anybody run into that? ill search through the thread
Old 07-27-2017, 04:27 PM   #946
OddyseusDSM
Talkin the mount? If you use his engine mounts yea. I personally want a rubber insulator so I'm gonna do a stock location trans and another mount hole for 3/4" farther back. Might not be as far back as collins kit but I'm running full interior and just making a weekend fun car. The 3/4" would allow the abs driveshaft/ non abs diff combination if I ever feel like going that way in the future. Only other option is to make a trans mount bracket.
I would assume you could push the engine farther forward if the mounts allow it. Do you mean sway bar? How bad is the interference?
Old 07-27-2017, 07:01 PM   #947
1UZVillain
1UZVillain's Avatar
Yeah i rather use the 4 holes, is it safe to use just the two holes?...i was thinking of making an extension and get a alot welded on the cross member to bolt the two front holes for support
Old 07-27-2017, 07:34 PM   #948
OddyseusDSM
Well you're using the solid mounts, right? So the engine won't twist so much if even at all. The bolts for the bracket are just holding whatever weight is on the trans mount. If you dont trust it I'm sure you could use angle iron and some square tube to create your own bracket much like the vq swap trans brackets I've seen. Collins was drifting on this, its probably fine.
Old 07-27-2017, 08:44 PM   #949
1UZVillain
1UZVillain's Avatar
ok just making sure, i wont be drifting anyway maybe autocross and road racing if i can, just want to cruise in my ride and attend meets and shows
Old 07-27-2017, 08:59 PM   #950
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Oh woah this thread is still alive. I don't even remember when I last posted.
Honestly most of this thread has moved over into FB groups.
I'm working on some interesting group buys for 1uz swap stuff.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 07-28-2017, 02:42 PM   #951
1UZVillain
1UZVillain's Avatar
im in the FB groups too. knowledge is power lol
quick question when you did yours did you change the oil pump, i havent heard issues with them, i kinda dont wanna do it right now, changing the water pump is not that bad.
Old 08-02-2017, 05:24 AM   #952
914Slide
914Slide's Avatar
I made mine outta some 1/4 angle iron all solid, same for the trans mount. i also use 2 bolts instead of the 1 to the cross member. Its a very smooth engine. I still have stock drive shaft with a stock welded diff.
Old 08-28-2017, 08:51 AM   #953
1UZVillain
1UZVillain's Avatar
money money money, is the only thing slowing me right now, took some loses. and i still have to get money for my exhaust lol im sticking in there tho
Old 08-30-2017, 07:20 AM   #954
914Slide
914Slide's Avatar
keep at it i need to tuck my ecu somewhere still i might just mutilate a glove box , I built my exhaust with 2 pieces of 10ft pipe i have a ton of pics i need to try to get them on this !
Old 09-01-2017, 11:06 AM   #955
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
Still have a new Collins adapters 1UZFE swap driveshaft for those interested.
Crazyced is offline   Reply With Quote
Old 09-27-2017, 06:57 PM   #956
914Slide
914Slide's Avatar
ds
bump this thread should be a sticky
Old 09-28-2017, 01:07 AM   #957
ingmar F
ingmar F is an unknown quantity at this point
I need headers....
ingmar F is offline   Reply With Quote
Old 10-30-2017, 07:37 AM   #958
1UZVillain
1UZVillain's Avatar
I finally got my money right, and the parts i was going to order goes up in price lol...still tugging along. fixing my steering rack etc. i need a program or app to post pics to forums
Old 12-20-2017, 01:40 AM   #959
PowerDrifter
PowerDrifter is an unknown quantity at this point
My 1uz at the track. 150 shot of nitrous coming up
https://www.youtube.com/watch?v=LPfZccpY0Vs
PowerDrifter is offline   Reply With Quote
Old 02-27-2018, 07:24 AM   #960
1UZVillain
1UZVillain's Avatar
nice, keep us updated on the progress, what did you run?
