Old 05-03-2011, 02:41 PM   #31
!Zar!
!Zar!'s Avatar
Were you really running 2.5* toe in? Excessive.
With ls1 torque I would toe in a little bit and run a bigger/stickier tire so that speed can be increased.
Assuming you are still using s14 se's as in the picture...
Old 05-03-2011, 04:04 PM   #32
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
I do toe out in front and toe in in rear... I dont know why so many people do zero toe all around.
pink godzila is offline   Reply With Quote
Old 05-03-2011, 04:22 PM   #33
ZX88
ZX88's Avatar
front camber; -3.5
Front toe 0
Front caster: stock
Rear Camber: -2
rear toe 0
SNOW PANTS OR NO PANTS.
Old 05-03-2011, 04:34 PM   #34
!Zar!
!Zar!'s Avatar
Toe out up front I like for the turn in and steering it give me when I'm doing da driftings.
Zero toe in rear allows frees up a little traction when compared to running toe. So it helps the lesser horsepower cars out. But as I said, it doesn't do much for increasing speed/stability.
Old 05-03-2011, 05:27 PM   #35
gobackwards
gobackwards's Avatar
gobackwards is an unknown quantity at this point
track/street probably. Shit kinda turns itself with front toe out.
gobackwards is offline   Reply With Quote
Old 05-05-2011, 05:51 AM   #36
Krimlin
Krimlin's Avatar
Krimlin is an unknown quantity at this point
Yep, stock KA with that much toe = pedal to the floor/top of 3rd/nice sustainable and controlable angle
But that's just me
Krimlin is offline   Reply With Quote
Old 05-05-2011, 04:20 PM   #37
fckillerbee
fckillerbee's Avatar
not everyone is a boss mmmkay. lol
Old 05-05-2011, 06:19 PM   #38
ayororo
ayororo's Avatar
Trader Rating: (25)
ayororo is an unknown quantity at this point
Feedback Score: 25 reviews
Hey guys my caster on the drivers side front is like closer to the door than the other side.
Cant make uturns without hitting wheel well (turning left)
and when i pull tire hits my side skirt.
is adjusting the caster possible on oem tension rods?
ayororo is offline   Reply With Quote
Old 05-07-2011, 05:46 PM   #39
naw_speed
naw_speed's Avatar
naw_speed is an unknown quantity at this point
no adjustments on OE tension rods
))-> sil front on.. time for rocket bunny kit<-((
naw_speed is offline   Reply With Quote
Old 05-07-2011, 06:07 PM   #40
naw_speed
naw_speed's Avatar
just got mine align today. this is what i,m runnin.
wheels: 18x 9.5 +20 with 225/40s fenders rolled and pulled (no spacers)
front
camber -1.4 wish had more at least -2
caster 8
toe .05
rear
camber -1.2
toe .12
everything within OE spec except front caster. was runnin f/caster at 10 felt to be too much and rubbed f/fenders. this is my DD and street brawler. third gear pulls are smooth. i don,t like tire wear on my DD tires so i try to stay as close to OE specs as possible.
Old 05-08-2011, 01:14 PM   #41
rage
rage is an unknown quantity at this point
Send a message via AIM to rage
prob bent control arm
rage is offline   Reply With Quote
Old 12-31-2011, 07:20 AM   #42
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Front
Toe 1/16 toe out
Camber -2.5*
Caster 6.5*
Rear
Toe 0
Camber 1.5
Thrust stock
Front camber should be set at whatever yields the most contact patch at lock.
Rear camber depends on setup as well. I have found that rear camber on a car can actually increase grip when the body rolls.
Caster is drivers preference.
Rear toe depends on power/tire setup.
Zar how much power were you putting down with this set up?
Originally Posted by Krimlin View Post
When I was running the KA:
Front:
Camber: -5.5*
Toe: 0*
Caster: OEM
Rear:
Camber: -2.5*
Toe: -2.5*
Caster: LOL*
Krimlin, how easier was it to drive/drift with your setup?
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 12-31-2011, 10:28 AM   #43
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
Lower car..
Toe set straight
add camber front
Take camber out rear
go drifting...
profit
It is simple if you don't think about it.
Couped_up'd is offline   Reply With Quote
Old 01-02-2012, 03:22 AM   #44
foreverdark
foreverdark's Avatar
foreverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfection
What size wheels and tire are you running?
I always run
Front:
Caster 7.25
Camber -4.5
Toe 0
Rear:
-0.5 Camber
Slight toe in rear.
Sr20det
17x9 0 offset 235 40 17 front and rear.
foreverdark is offline   Reply With Quote
Old 01-02-2012, 09:59 AM   #45
niteridaz503
ME? mostly stockers as drift spares nothing fancy or wider than 8.5
