10-06-2013, 12:02 AM | #91 |
I will be doing a solid cali legal build soon too. I can't wait to see what you do with that one. Can you tell me about your interior though? Where did the door trim come from? Also the climate control module. Keep up the good work.
10-07-2013, 09:24 AM | #92 | |
Trader Rating: (71)
Feedback Score: 71 reviews
are you talking about the bride fabric? its a jdm climate control. search for s13 dcc ive seen a few on the forsale thread section. |
10-28-2013, 11:31 PM | #97 |
Trader Rating: (71)
my tomei sr20 oil pan finally came after it was backordered for a few months.
just incase some1 wanted to see what tsubaki timing kit for the ka24de. bought me a better powdercoating system. spectracoat es-02wp not much update thats because i've been busy building my powdercoating oven..... cheap but works like wonder...specially when i need to crank out 1000 rivets lol |
10-29-2013, 11:45 PM | #98 |
Can you post more on the powder coating oven?
What are you planning on using for a heating element and sealing it? Surely rivets cant be enough? Thanks -Kyle |
11-20-2013, 10:25 AM | #101 |
what is your harness mounted onto to?
also, wen you installed the NPR rings, were they already gapped to factory specs? i got a set myself and im rebuilding my ka and wondering before i start shaving away love the build btw! |
11-20-2013, 12:23 PM | #102 | |
Trader Rating: (71)
not sure if the npr rings are pre-gapped to oe specs. i havent checked them yet. slide them on ur cylinders see if they are and perhaps u can lmk if they are within oe specs |
12-31-2013, 01:32 AM | #105 |
Trader Rating: (71)
been a while since i updated the thread. hope everyone had an awesome christmas! 2014 here we come!
been busy building my big ol powdercoating oven. not quite finish yet but soon to be running and make some side money! haha havent really done much to any of the two KA's im building but been buying parts after another lol....parts filing up and got no more room! BC intake/exhaust valve guides & supertech valve seals. incase some1 needs part# for supertech valves seals vs-n7e & vs-n7i found an xcessive intake manifold for a decent price few goodies i got for christmas.... finally bought work emotion XD9 18x10 +18 rears & 18x9 +20 frts freebies frm WORK!!! other goodies i got.....go pro hero3 white edition and the bose soundlink mini(sounds amazing for a lil speaker) Last edited by hpipro4; 12-31-2013 at 07:30 PM.. |
12-31-2013, 09:07 AM | #106 |
Awesome build, in love with your interior, if you ever wanna sell those calipers let me know
***FortuneMinds*** 95 240SX S14 / 14 Lexus IS250/ IG / Twitter: juvi22003 |
01-27-2014, 01:01 AM | #107 |
Trader Rating: (71)
didnt think id ever get into the snap-on bandwagon but guess what!!! i did! got em for cheap and im cheap so why not.
luv this fkerrrs! im going to do custom intercooler pipings n such so im expanding my tig welding equipments! got a pair of torchwear gloves. ckworldwide ck9 & ck17 tig torches w/superflex cables. more consumables & stronghand nomad welding table. 2% lanthanated is all i use both AC n DC was watching the tomei ka24de-t build, well i thought this valve spring compressor is pretty neat! starting to build the other KA engine..... |
01-27-2014, 10:51 PM | #110 | |
Trader Rating: (71)
not sure why but their the cheapest i found with ckworldwide stuff. customer service wasnt so good at 1st but when they replied it went smooth after that. the welding table i bought off summit racing since i had 20off. |
01-28-2014, 08:40 AM | #112 |
A whole lot of goodies, trying to find one of those intake manifold for myself.....
01-29-2014, 09:19 AM | #113 | |
01-31-2014, 01:23 AM | #114 |
Trader Rating: (71)
havent been productive lately with the build but guess you could say i got some work done!
checked the head mating surface for flatness, its good no warpage. thinnest feeler gauge i had was .0012" and used starrett 380-24 straight edge. looks like i need to replace all the exhaust guides. checked valve deflection using dial indicator and they average around .015" oe limit is .008". intake side are around .005" so their good. was going to make a DIY valve spring compressor but found this on amazon for a decent price made by neiko. its a universal and already tried it out and its works good. |
05-22-2014, 06:27 AM | #117 |
Looking like a great build for sure.
I just skimmed through, but only saw the picture of the block back from machining. Did you have them deck the front timing covers when they did the block? Like take an equal thickness off of all parts. If not, you'll have a leak there where they meet. Just wanted to check before you get it all back together.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
05-22-2014, 06:55 AM | #118 | |
Great work....how did your motor perform with the
I am debating on going this route.....
wanted:filter relocation, front Coilover, Brake, Rims,seats,quick release
05-24-2014, 03:40 AM | #119 |
Enthalpy is about as respected as it gets in terms of rom tunes. I'd use one without hesitation.
BRICKHOUSE PRODUCTS
08-04-2014, 11:51 PM | #120 |
Trader Rating: (71)
been a while since i updated my build thread. Was out of the country for a month and when i came back, decided to change a few things on my setup.
this what the engine looked before i left the country... came back and decided to take it all apart because im picky like that lol spent a few hundred dollars on precision measuring tools the engine above, i decided im going to run all stock except wiseco piston w/stock rods. learn how to use MS on it and use it for smog purpose. heres my future plan for my other built KA wiseco .020 eagle rods arp main and headstuds holset hx40 fullrace twin scroll mani clevite bearings cosworth hg bc 264 jwt adj. cam gears bc std intake and exhaust valves bc valve guides supertech valve guide seals supertech dual valve springs z32 tranny ID1000cc e85 mspnp2 starting to collect parts for the nxt build already.... got my hx40 and been talking to timsturbo about t3 divided housing and billet comp wheel. came with a t4 divided housing and fullrace ka mani uses t3 divided so ill need a different turbine housing. has 8blade comp wheel |
