09-04-2014, 09:02 PM | #1 |
95 Ka24de dies when given gas
Know there is a thread right below this one about the same problem, but different circumstances so I figured I'd open a new thread. Anyways as title states when I give the car gas it dies and pretty fast too. So far ive replaced the MAF,TPS,plugs & plug wires. Besides it dying its running super rich tons of black smoke.
Heres a video of me showing the problem, the MAF was unplugged in here since it was the old one. When i had it plugged in it would die shortly after starting https://www.youtube.com/watch?v=bCZk...K2Uv6g&index=1 |
09-06-2014, 07:38 AM | #5 |
I might have a old fuel pump from my last s13, but I can hear it prime and it starts and idles for like 2 mins and then dies
09-06-2014, 07:57 AM | #8 |
Haha I'm checking fuel pressure tonight I got a guage for it and I'm hoping my fuel pump is the problem cause its having more and problems starting up then when I first started having this problem
09-06-2014, 08:02 AM | #9 |
Haha for you it looks whatever is supposed to keep the idle up (not sure if it's an actual part or the ecu's job) isn't working...my car does the same thing almost but it won't actually die..I have an sr and after accelerating I'll let off and if I don't tap the gas when the rpms are dropping it'll drop down to 500rpms and my lights on the cluster will come on for a split second then the engine kicks the rpms back up to 900
(My issue could just be the bov venting to atmosphere tho) For the OP def sounds like a fuel pump issue then or you're just running out of gas haha |
09-06-2014, 08:13 AM | #10 |
Yeah I definitely have gas haha I made sure of that so I didn't look like a dumbass if I was out of gas. I hear my pump turn on but my guess is its on its way out and barely running
