Old 08-09-2009, 03:28 AM   #1
92sxMike
92sxMike's Avatar
92sxMike is an unknown quantity at this point
s13 s13 speed govenor issue.
Hi guys, I've been reading around the net about how you can remove the speed limiter on s13's, but be4 I snip the ecu wire and fubar something up I'd like to know if anyone has done this and works 100% without any problems. I did do a search and it's been asked before but no solution to my knowledge and the post was made 1/20/2009.
92sxMike is offline   Reply With Quote
Old 08-09-2009, 03:52 AM   #2
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
hmmm, id like to know that too.
the governor stops me too much
lol
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 08-09-2009, 03:23 PM   #3
dub40sx
Theres two simple sensors that if you unplug there seems to be no side effects and you can go as fast as your car will allow.
Old 08-09-2009, 05:35 PM   #4
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
just get a Auto ECU....
or theres a sensor or something u can cut/remove...im not too sure about
this has been covered many many times before
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 08-10-2009, 10:28 PM   #5
92sxMike
92sxMike's Avatar
well i need to find a solution to this because its really annoying. So if anyone can please help me out as what wires to snip and what not.
Old 08-10-2009, 10:31 PM   #6
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
The guy right above you told you how to do it. Put an automatic ecu in it. automatics ecus have no fuel cuts. If you would have searched you could have found this out in the time it took you to make this thread.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 08-10-2009, 10:38 PM   #7
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
Dude slow the hell down if it's really annoying.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 08-10-2009, 10:44 PM   #8
blackrms13
blackrms13's Avatar
well...not everyone can read...u know?
