Old 07-13-2014, 02:02 PM   #1
jerryscherry
jerryscherry is an unknown quantity at this point
Is the s13 T25 Exhaust Turbine Housing same as the s14/s15 t28?
Is the s13 t25 exhaust turbine housing the same as the s14/s15 t28 turbos? are they interchangeable?
According to this website the specs are the same o.o?
http://www.drift-connection.com/sr20...p#.U8LlbPldWRY
" Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. "
my g2871r 0.64 housing does not bolt onto the stock sr manifold because of the way the t25 flange is setup. no space for the studs to go through.
wanted to know if i can swap in a t25 housing o.O?
jerryscherry is offline   Reply With Quote
