Old 06-26-2012, 07:53 PM   #1
vq35SMASH
vq35SMASH's Avatar
vq35SMASH is an unknown quantity at this point
Exclamation S13 diff in s14?
Hey zilvanians, quick question. My buddies bought a welded diff for his s14. They dummy bought a s13 diff. The question is can the internals from the welded s13 fit into his s14 open diff? What would have to be changed if so? Or is he screwed and has to weld a new diff? Thanks ahead guys
SLIDE SYNDICATE
vq35SMASH is offline   Reply With Quote
Old 06-26-2012, 07:55 PM   #2
89s13sd
89s13sd is an unknown quantity at this point
just swap the back cover and it should be good, no need to swap internals
89s13sd is offline   Reply With Quote
Old 06-26-2012, 07:57 PM   #3
Kaomon
Trader Rating: (77)
Kaomon is an unknown quantity at this point
Feedback Score: 77 reviews
first off, I'll spoon feed the answer to you as everyone else will bash you for not searching.
your problem is an easy fix.
all you need to do is use a s14 diff cover (2 bolts) on the s13 differential, which is a direct bolt-on since the s13 diff cover has 4bolts.
Next time take some initiative to search!!
Good Luck!!
Kaomon is offline   Reply With Quote
Old 06-26-2012, 07:58 PM   #4
vq35SMASH
vq35SMASH's Avatar
All the bolts line up? It was still on the car but I thought they looked a little different but it just could be me..lol
SLIDE SYNDICATE
Old 06-26-2012, 08:00 PM   #5
vq35SMASH
vq35SMASH's Avatar
Thanks a bunch...and for the bashing I needed a quick answer and my phone sucks...it let me post but not search
SLIDE SYNDICATE
Old 06-26-2012, 08:00 PM   #6
Kaomon
Trader Rating: (77)
yes, all 8 bolts on the diff cover will line up!
Old 06-26-2012, 08:54 PM   #7
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
we are just telling you it fits cause we want you to screw up and waste your time.
eek is offline   Reply With Quote
s13, s14, silvia, sr20, welded diff
