05-20-2013, 02:34 PM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
s13 radio harness problem
try to redo my harness prior to install sony head unit that has FAILURE on the screen
i got the diagram from google but i found two blue wires (both on when acc) and two red w/ black stripe (both always on from 12v battery) in my harness |
05-20-2013, 04:05 PM | #2 |
Ok so what's the problem? I would just combine the wires and wire them accordingly to the head unit. The second set of wires might of been put there by a previous owner to power a cd changer or amp.
05-21-2013, 08:41 AM | #5 |
Go to Walmart and buy an OEM Nissan stereo adapter harness. Takes all the guess-work out of it; and makes for a much cleaner installation.
05-21-2013, 01:09 PM | #6 | ||
Maybe there was an eq or something installed before.
LoverTechnologies "Half Broken Things!" |
05-21-2013, 09:05 PM | #8 |
If your not going to use them and they are not in a plug or socket, snip the end of exposed wire and tape them up. A short there will cause you unwanted problems.
