Old 02-27-2014, 08:40 AM   #1
badlittlemojo
badlittlemojo is an unknown quantity at this point
ecu codes
ok i've had two mechanics look at the car for my battery draining issue and all the can say is it iss either a shorted wire on my egi fuse or a bad ecu. i did a code check on the ecu and got multiple codes. 21: ignition siganl primary. this is the one the concerns me. does this mean the ignition portion of the ecu is bad? any help is appreciated.
badlittlemojo is offline   Reply With Quote
Old 02-27-2014, 04:33 PM   #2
bad dog
bad dog's Avatar
bad dog is an unknown quantity at this point
i would get a spare ecu , they are about $50 ebay , if that's not the problem at least you will have a spare .
bad dog is offline   Reply With Quote
Old 02-27-2014, 04:40 PM   #3
badlittlemojo
i would but i can find the WM model anywhere but at the dealer. and if a use a J7 for the automatic then i might be getting extra codes i dont really need
