Old 06-03-2009, 12:28 PM   #1
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
ALT 75A Fuse Blows When Turning over in gear.
Have this strange problem, my ALT fuse, the main fuse for the car, keeps blowing. It happens every time I accidentally turn over the car in gear then press the clutch fast to stop it from driving forward.
So what Im doing is, turning the car over in gear, car jerks forward, then I rush to press the clutch because I forgot it was in gear. Then Boom the 75A fuse goes, $14 bucks gone.
This didnt happen a couple years back, now its doing it. Its fairly common to do this in a S13 cause theres no clutch switch. And I'm forgetful.
ANY HELP/SOLUTION would do... even if I have to add something to stop the fuse from getting tuned.
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 06-03-2009, 12:30 PM   #2
Om1kron
Om1kron's Avatar
you sure you don't have an exposed wire somewhere that hits the chassis every time it "jerks forward in gear"?
Wayne
Old 06-03-2009, 12:47 PM   #3
kuruptR
kuruptR's Avatar
yes 100% sure.
Old 06-03-2009, 12:56 PM   #4
Slidin240Wayz
Slidin240Wayz's Avatar
Slidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfection
Check all your harnes...under wheel well...?
I would also cancel the clutch switch...connect both wires...no need to press clutch to start car.
Slidin240Wayz is offline   Reply With Quote
Old 06-03-2009, 01:13 PM   #5
kuruptR
kuruptR's Avatar
Wiretuck, but charging harness was left untouched. Anything starter related was not cut.
Car does not have a clutch switch, possibly a Canadian 240 thing... but s13's here start with no clutch.
Old 06-03-2009, 01:17 PM   #6
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
Ya, pretty sure it's a Canadian thing. Hmmm... check your charging harness maybe?
JVD is offline   Reply With Quote
Old 06-03-2009, 01:48 PM   #7
jmac636
jmac636's Avatar
jmac636 is an unknown quantity at this point
Maybe you should put a switch on it or just remember to push in the clutch.
S14 Turbo LS1/t56 http://www.playloudclothing.com/
jmac636 is offline   Reply With Quote
Old 06-03-2009, 03:10 PM   #8
kuruptR
kuruptR's Avatar
Solution: I had the Alternator source backwards with the starter source.
