08-25-2014, 01:18 AM | #1 |
AEM Oil pressure gauge issue
Gauges are all linked for power, all AEM, (boost,wideband,water temp, and oil pressure) The OP gauge warning light would flash like it wasn't getting signal from the sensor... I checked the power coming out of pins where it goes to the harness to the sensor and nothing. Sent the gauge back to AEM. I forgot to send in the sensor itself, but didn't think it was an issue since I was sure the gauge was the issue. They send it back in working condition..... but the gauge reads 10psi constantly.. same if the car is or isn't running....
Any ideas what the issue could be? Thanks |
08-27-2014, 09:35 PM | #2 |
Trader Rating: (37)
Feedback Score: 37 reviews
If the gauge is constantly reading 10psi, sounds like a faulty sensor. I don't exactly see AEM sending back a non functioning gauge. Never knew though.
Did you buy the gauge brand new, or second hand? |
08-29-2014, 05:00 AM | #4 |
Swap sensors, they are typically the first part to fail.
My SR20VET |
