Old 02-08-2014, 12:24 PM   #1
abaron13
Trader Rating: (24)
abaron13 is an unknown quantity at this point
Feedback Score: 24 reviews
S15 SR20DET Running Lean
I got my new swap in and running but it's running way too lean at all times. It seems like the fuel map is off or something. The maf is fine, no boost/vacuum leaks, fuel pressure is perfect and it has a brand new fuel pump. What could be the reason for it running so lean besides a bad ecu?
abaron13 is offline   Reply With Quote
Old 02-08-2014, 12:57 PM   #2
pacotaco345
pacotaco345's Avatar
Have you checked fuel pressure? If you have an exhaust leak before the o2 sensor that can cause it too
Old 02-08-2014, 01:15 PM   #3
abaron13
Trader Rating: (24)
Fuel pressure is good, as previously stated. No exhaust leaks either
Old 02-08-2014, 01:49 PM   #4
ka-t
ka-t is an unknown quantity at this point
all stock ?
ka-t is offline   Reply With Quote
Old 02-08-2014, 01:50 PM   #5
abaron13
Trader Rating: (24)
Other than a fmic it's all stock, yes.
Old 02-08-2014, 01:55 PM   #6
bmxer882x
bmxer882x is an unknown quantity at this point
Are u missing really bad? Like one cylinder isn't getting fuel? Or is it even like all cylinders are being starved? If it's just one check your injectors. (To test pull off a coil from each cylinder when the cylinder gets no change in idle your problem is in that one)
bmxer882x is offline   Reply With Quote
Old 02-08-2014, 01:57 PM   #7
abaron13
Trader Rating: (24)
No the car runs and idles fine, I can't figure out what's up with it.
Old 02-08-2014, 02:03 PM   #8
bmxer882x
If it runs and idles fine I would say u have an exhaust leak. Recheck all your fittings before your wideband. Also check it's completely screwed in and tight.
Old 02-08-2014, 02:05 PM   #9
abaron13
Trader Rating: (24)
I triple checked that. It smells like it's running lean, and it hesitates under certain loads while driving.
Old 02-08-2014, 02:07 PM   #10
abaron13
Trader Rating: (24)
It's throwing me for a loop because I've already checked every logical thing it could be, other than swapping in another ecu, mainly because I can't find one anywhere...
I posted here as a last resort to see if I missed something stupid.
Old 02-08-2014, 02:23 PM   #11
801nismo104
801nismo104 is an unknown quantity at this point
do you have a wideband or are you just guessing its lean?
801nismo104 is offline   Reply With Quote
Old 02-08-2014, 02:23 PM   #12
abaron13
Trader Rating: (24)
I have an aem wideband
Old 02-08-2014, 03:22 PM   #13
bmxer882x
Only other thing I could think of is check and make sure ur ecu doesn't have a room tune in it. Or check to see that you are getting a solid 12 volts at the injectors. Iirc mine was 12.36 volts.
Old 02-08-2014, 03:28 PM   #14
abaron13
Trader Rating: (24)
That was the first thing I checked when I got the swap, no rom tune. That should make it run rich instead of lean anyways, I would think. I'll look at the voltage
Old 02-08-2014, 03:58 PM   #15
abaron13
Trader Rating: (24)
The ecu is throwing a code for the maf, but the maf and maf wiring is fine. I'm also getting good voltage at the ecu (1.4v at idle)
Old 02-08-2014, 04:17 PM   #16
jaxshawn
jaxshawn is an unknown quantity at this point
did you get the swap as a full set up, s13/14 sr20's use 370cc injectors but the s15 uses 434cc (400 something not sure on exact)
jaxshawn is offline   Reply With Quote
Old 02-08-2014, 04:18 PM   #17
abaron13
Trader Rating: (24)
480cc and yes I have the full swap
Old 02-08-2014, 04:23 PM   #18
jaxshawn
adjustable fpr or stock?
and what was youe fuel pressure at idle
Old 02-08-2014, 04:26 PM   #19
abaron13
Trader Rating: (24)
Stock 43psi
Old 02-08-2014, 04:34 PM   #20
jaxshawn
did you calibrate your wideband before installing it?
Old 02-08-2014, 04:45 PM   #21
abaron13
Trader Rating: (24)
Aem widebands dont require calibration. However it is on the right setting.
Old 02-08-2014, 05:11 PM   #22
oni jake
oni jake is an unknown quantity at this point
The MAF sensor code could mean anything involving air flow. You have a boost leak somewhere if you're absolutely sure everything else is fine.
oni jake is offline   Reply With Quote
Old 02-08-2014, 09:21 PM   #23
Tom N
Tom N is an unknown quantity at this point
How do you know for sure the maf is good?
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 02-08-2014, 09:56 PM   #24
bmxer882x
Just off of memory there is two different injector sizes. The 480 in the type r and the 444 (I think). The 480 came with the db turbo where as the other was in the automatics with a t28 journal bearing. I'm not sure but there should be two different ecu's. Do some searching and make sure u have the right injector/ecu combo. Sorry for not knowing exactly just trying to point u in a direction to look.
Old 02-09-2014, 09:04 AM   #25
oni jake
All OEM manual S15 ECUs are tuned the same way; injectors are the same across the board for every stock S15 turbo motor out there.
EDIT: When ECUs go out, they don't make A/F ratio mistakes. If something were to happen, the ECU goes into LIMP mode if possible. If not possible, the ECU will shut down all together. Your problem has nothing to do with the ECU
Old 02-21-2014, 05:44 PM   #26
abaron13
Trader Rating: (24)
Ok I had the injectors cleaned and flow tested. They're fine. Good fuel pressure. The entire fuel system itself is fine. I have no boost leaks. And there are also no exhaust leaks pre wideband. What else could it be other than the ecu not telling the injectors to dump enough fuel?
Old 02-21-2014, 06:00 PM   #27
Tom N
What fuel pump? Have you checked voltage at the pump?
Are you positive you have a good working S15 maf?
Old 02-21-2014, 06:04 PM   #28
abaron13
Trader Rating: (24)
It's a brand new dw 220 and the voltage is good. I questioned my maf so I bought a known working maf and it did the same thing. The voltages to and from the maf are good as well.
Old 02-21-2014, 06:13 PM   #29
Tom N
Ecu could have a non stock tune on the chips.
Old 02-21-2014, 06:15 PM   #30
abaron13
Trader Rating: (24)
I cracked it open as soon as I got it, there's no daughter board.
