Old 03-16-2014, 09:01 PM   #1
nick.g1994
nick.g1994's Avatar
nick.g1994 is an unknown quantity at this point
180sx sr20det running fully sick. Tps?
Okay, new member here first post.
Great site.
My sr20det 180sx runs like [email protected] Runs rich as (black plugs). Bad fuel economy (20L per 100klms)
It won't rev past 3500ish rpms unless I rev it quickly and it backfires through intake
But if I unplug the tps it runs fine, revs, no backfiring. I've searched the problem and people say they've replaced the tps and the problem has still been evident. I don't have the money to get items that don't fix the problem
I can't check timing cause idle is 1100rpm and iacv screw is stripped. Any help would be appreciated, thanks! I can't check codes cause I have no leds on my ecu and no check engine light to see flashes. The cars a 92 model
nick.g1994 is offline   Reply With Quote
Old 03-16-2014, 10:25 PM   #2
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
if it won't rev past 3k, its almost always a bad maf.
Old 03-16-2014, 10:34 PM   #3
nick.g1994
nick.g1994's Avatar
It only won't rev past 3k if I rev slowish and If I unplug the tps it does rev fully
Old 03-17-2014, 12:04 AM   #4
nick.g1994
nick.g1994's Avatar
Cold vacuum is 20 inHg. Gauge is teed off the fpr by old owner
Old 03-17-2014, 09:35 AM   #5
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Sounds like maf issues to me too. Start by going over the wiring and giving the maf a good cleaning with appropriate spray cleaner
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 03-18-2014, 03:17 AM   #6
nick.g1994
nick.g1994's Avatar
I've cleaned maf with maf cleaner spray already
I set timing using the rev method cause my idle is too high
I've cleaned throttle body and iacv
I'll let you know if it happens again, thanks for the help everyone
Old 03-24-2014, 04:52 AM   #7
nick.g1994
nick.g1994's Avatar
ImageUploadedByTapatalk1395658270.375154.jpg **UPDATE** the O2 sensor wiring has a break in the power side of it and it would have since I got the car. Repairing that tomorrow
Old 03-26-2014, 01:03 AM   #8
nick.g1994
nick.g1994's Avatar
Fixed that wire with no change ffs
Just spent an hour changing the plugs and adjusting timing for no reason
Old 03-26-2014, 02:00 AM   #9
wrxstiswap
wrxstiswap is an unknown quantity at this point
Really sounds like your maf man. Unplug it and see if there a change in idle. You can check the tps with a multimeter. If its bad I believe I have one or two on spare throttle bodys pay shipping and its yours.
wrxstiswap is offline   Reply With Quote
Old 03-26-2014, 02:13 AM   #10
nick.g1994
nick.g1994's Avatar
With maf unplugged car dies or won't rev
Old 03-26-2014, 02:34 AM   #11
nick.g1994
nick.g1994's Avatar
Where you located btw?
Old 03-26-2014, 01:50 PM   #12
nick.g1994
nick.g1994's Avatar
What are you guys on about?
Old 03-28-2014, 08:52 AM   #13
ultimateirving
Sorry dude those are spam bots.
What I thinking is you may have a leak somewhere if the maf checks out. Do a boost pressure leak test because turbo.
Z32 with lq4 swap
Old 03-28-2014, 08:04 PM   #14
nick.g1994
nick.g1994's Avatar
Wanted: 180sx redtop sr20 throttle body and tps
Old 03-28-2014, 09:37 PM   #15
brndck
brndck's Avatar
post in the right section then
Old 03-28-2014, 09:38 PM   #16
nick.g1994
nick.g1994's Avatar
No permission to create a wtb post, already tried
Old 03-30-2014, 04:40 AM   #17
sdtjsy
sdtjsy is an unknown quantity at this point
sdtjsy is offline   Reply With Quote
