11-24-2009, 12:58 AM | #1 |
quick question. need answer
i searched but i want to get confirmation on this.
s13 sr20det The wastegate nipple needs to be connected to a nipple on the cold side of my intercooler pipes? think a muffler shop could do that? also i have a frsport greddy hot pipe. the flange screws on but it doesn't line up where i need it to make my recirculating hose fit right. can i tell them where it needs to be and just weld it up so when i bolt on the BOV it won't leak? thanks
'02 S2000 pte5857 tubo'd '00 integra ls - daily |
11-24-2009, 01:04 AM | #2 |
just run a vaccuum hose from the wastegate nipple to a nipple on the throttle body, and any good welding shop should be able to modify your piping however you want it if you got the cash.
11-24-2009, 01:10 AM | #3 |
the lower left vacuum port on the throttle body is blocked per all the posts i found. should i just hook it up to that one?
