Old 07-13-2011, 11:08 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Parts CLEARENCE, more added! Nismo, sways, SR, Z brakes, MORE!!!
NISMO clutch and flywheel setup for SR
I was REALLY looking forward to using this setup on my N/A SR, but unfortuanetly that didn't work out. All parts are authentic NISMO parts and are in very good shape. There is LOTS of life left on the clutch disc, minimal heat spots on the flywheel, no noticeable wear on the flywheel, no heat spotting on the pressure plate.
clutch disc P/N: RS225
pressure plate P/N: RS540
flywheel P/N: RS541
$400 FIRM
Autometer mechanical oil pressure guage
This is an autometer mechanical oil temperature guage with the plastic tube. All you need is an adapter to screw it into your oil pressure port to make it work. The guage is als lighted as well. It is in good working condition. The size of the guage is 2"...
$30
Redtop SR20DET coilpack harness
This is a great condition coilpack harness from a redtop SR20DET. All connectors, insulation, and wiring are in great condition.
$20
S-14 SE stock rear swaybar (bottom in pic)
This is a stock S-14 SE 16mm hollow rear swaybar. It will work with either s-13 or s-14. The bar is in good shape, no bends, no significant rust. The endlinks are still attached to the bar, but I do not have brackets and bushings.
$10
S-13 stock rear swaybar w/poly bushings (second from bottom)
This is a stock s-13 15mm solid rear swaybar with energy suspension urethane bushings and brackets. The bar is in good shape and is what I used to use in the rear on my track car.
$15
S-13 SE 17mm rear swaybar (middle in pic)
This is a little thicker than a stock rear swaybar for those who want to try a small change. No bushings/brackets/or endlinks are included, but I do have urethane bushings available for this bar as well for an additional charge.
$15
S-13 hicas 21mm solid rear swaybar (second from top)
This is the stock swaybar off a usdm s-13 w/super hicas. It is 21mm in diameter and is solid. This is a significant upgrade from stock. Bushings/brackets/endlinks not included...
SOLD!
S-13 JDM 22mm hollow rear swaybar (top in pic)
This is definitely the most desirable stock rear swaybar out there. Is is just a little under 22mm in diameter and is hollow in construction. It is very light and possibly one of the best rear swaybars available period. Bushings/brackets/endlinks not included...
SOLD!
S-13 25mm front sway, adjustable, w/bushings (top in pic)
This is the swaybar that I personally used on my 240. It is a stock s-13 SE 25mm front swaybar, but it has been drilled for a stiffer adjustment. Trust me when I tell you that drilling out those holes was a big PITA, but it made a large difference in front end stiffness. Included are urethane bushings and brackets.
SOLD!
S-14 27mm hollow sway, adjustable (bottom in pic)
This is a stock s-14 27mm hollow front swaybar, that has also been drilled out for a stiffer adjustment. This was also a big PITA to drill as well. This bar can work for s-13 or s-14. No bushings/brackets/endlinks included...
$25
S-13 stock front endlinks w/poly bushings
I used these before I went spherical. The bushings/joints are in good shape and the bushings are energy suspension urethane.
SOLD!
S-13 15mm poly rear swaybar bushings (unpackaged in pic)
These are brand new urethane bushings for a stock s-13 15mm rear swaybar.
$10
S-13 17mm poly rear swaybar bushings (bagged in pic)
These are also brand new and pretty rare. Most companies don't offer bushings for the 17mm rear bars since they're not very common, even on SE's...
SOLD!
Wedge Engineering driver's seat bracket s-13/s-14
This is a Wedge Engineering driver's side seat bracket for an s-13 or s-14 chasis. It is in perfect shape, no issues.
$50
S-13 DOHC throttle cable X2
This is a stock s-13 DOHC throttle cable. It is longer than the SOHC one and is necessary for a dualcam swap. I actually found another one, so there are two available...
SOLD!
Crossdrilled s-13 rear rotors
These are crossdrilled rotors for stock s-13 or s-14 rear brakes. The rotors have been drilled for 5x114.3 as well so they will work for either 4 or 5 lug. They're in good shape and have plenty of meat left on them. I am not sure of the brand though.
SOLD!
Agency Power 300zx conversion line set
This is a full set of agency power 300zx conversion brake lines. This is a full set, front and rear. The lines are in good shape and all fittings are included.
SOLD!
Porterfield R4S 300zx brake pads
This is a full set, front and rear, of used Porterfield R4S brake pads for 300zx calipers. The pads are in very good shape. They have lots of meat left, just a little dusty from sitting on the shelf. I used them for a couple months and then the car got de-comissioned.
$75
PAIR of 15mm, 5x114.3 spacers
This is a pair of 15mm thick, 5x114.3 bolt pattern, slip on wheel spacers. These were originally bolt-on, but I knocked the studs out. If you wanted to you could make them bolt-on spacers again, you just need to get the correct wheel studs for them. These are the regular silver ones in the pic.
$25
PAIR of 20mm, 5x114.3 spacers
This is a pair of 20mm thick, 5x114.3 bolt pattern, slip on wheel spacers. These were originally bolt-on, but I knocked the studs out. If you wanted to you could make them bolt-on spacers again, you just need to get the correct wheel studs for them. These are the black and silver ones in the pic.
$25
Recaro Z-31 300zx bottom mount seat brackets/sliders
I have these leftover from a pair of recaros that I came up on. They are a pair of recaro seat rails/sliders for a bottom mount seat in a z31 300zx. The only labels were on the seats themselves and they said "300zx" on them so they were a complete recaro bolt-in seat set. Fitment is awesome, the seats sit nice and low. These will probably work with other bottom mount seats as well as they have a couple extra mount points. Included is both the driver's and passenger's side sliders/brackets.
$80
racepar1 is offline   Reply With Quote
Old 07-13-2011, 11:33 PM   #2
novita1021
novita1021's Avatar
Trader Rating: (34)
novita1021 is an unknown quantity at this point
Feedback Score: 34 reviews
Interested in spacers hit me up 951 271 1114
novita1021 is offline   Reply With Quote
Old 07-13-2011, 11:35 PM   #3
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
ooo Kind of want those spacers :P
iamtheyi is offline   Reply With Quote
Old 07-14-2011, 03:29 PM   #4
racepar1
racepar1's Avatar
Since I'm at work I can't really be on the phone right now, but I will shoot you a PM...
I would kind of like you to buy them...
Old 07-14-2011, 07:06 PM   #5
ka24det92
ka24det92 is an unknown quantity at this point
how much for the lines shipped to 77099
ka24det92 is offline   Reply With Quote
Old 07-14-2011, 07:08 PM   #6
Edwin562
Edwin562's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
would the wedge brackets fit a recaro SRD seat???
Old 07-14-2011, 09:55 PM   #7
racepar1
racepar1's Avatar
I'll PM you with a shipped price...
They should, but sliders are not included.
Old 07-16-2011, 03:12 PM   #8
racepar1
racepar1's Avatar
First bump........
Old 07-16-2011, 03:15 PM   #9
rob22
rob22's Avatar
Trader Rating: (50)
rob22 is an unknown quantity at this point
Feedback Score: 50 reviews
why did you knock thoses wheel studs out of the spacers?!
im looking for those EXACT specs
wtb s14 roof wing/spoiler! pm me
rob22 is offline   Reply With Quote
Old 07-16-2011, 03:18 PM   #10
s13silvia123
s13silvia123's Avatar
i'll take the rear cross drill rotors if you still have it, pm me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
Old 07-16-2011, 07:44 PM   #11
racepar1
racepar1's Avatar
Because I had 50mm long wheel studs...
If you've got free time you could go to the junkyard and get some studs that will work with the spacers for free.
Yes they are still available, I will send you a PM right now.
Old 07-18-2011, 06:15 PM   #12
racepar1
racepar1's Avatar
Last bump........
Old 07-20-2011, 02:50 PM   #13
shinmei-2006
shinmei-2006 has a little shameless behavior in the past
on the spacers, are the splines for the studs the same as s14/s13?
shinmei-2006 is offline   Reply With Quote
Old 07-20-2011, 03:07 PM   #14
racepar1
racepar1's Avatar
I don't know, actually the spacers are now listed with some wheels anyways...
