Off Topic Chat All non related chat goes here. |
#1111 | |
AFC #1
![]() Join Date: Oct 2003
Comments should be taken as Opinions not as Statements of Fact ![]() |
#1113 |
As an Alpine retailer, what are your thoughts on the CDE-W235BT?
I'm in the market for an inexpensive double DIN unit for my 2012 Fit, I'm a fan of Alpine, I'm just unsure about the aesthetic of a non-touchscreen double DIN. However, if its a quality piece....I may be swayed more easily. |
#1114 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
The KS Mini is their line of small motorcycle amplifiers, but I typically don't use them. The new XDi V2 amplifiers are so small that they will fit in virtually anything... and there are a lot more amplifier offerings in the XDi V2 lineup. However, the brand new Moto series will most likely replace the KS Mini series. Even smaller than the KS Mini and way more powerful. The KS Mini series has been around for several years... so it was time to replace it.
I would use Norton Speedgrip. Quote:
#1115 |
Whats going on sir! First off, AMAZING machine and legendary work on it!
I was wondering if you would be willing to divulge a bit more information on how you did your rear quarter 25mm roll/pull? I am currently trying to make room for some new wheels on my 1992 Hatch that I have had for 6 years now. I am committed to keeping the quarters stock metal but need the extra room. I had rolled the quarters many years ago with my Eastwood roller and they are still clean/not dented etc. What I am wondering is how did you get the perfect arch/pull without getting all wavy? Did you have to cut or weld anything inside the wheel well? I have literally poured over every post you have made on your blog/nico/ and here trying do find out how you pulled it off lol. Any insight would be greatly appreciated! Thanks! Last edited by nissanhatchie; 01-18-2015 at 05:18 PM.. |
#1117 |
Broadfield, I want to change the brake hardlines on my firewall to AN fittings.
What kind do you think I should use? Also, I want to do aluminum hard pipes to and from the radiator, how would you tackle that?
#1118 |
Hey so about two years ago I purchased a viper remote start 2 way remote start kit from you worked perfectly always until this past year it sat while undergoing a full motor rebuild and engine bay shave/paint.now that I got it all hooked up and was ready to start it the starter would always have power at all times and wants to start..( the starter keeps clicking) and make sure by using a test light.no matter if the key is off and out of the ignition the starter still has power..I messed with it and pin pointed it to the alarm system..when I remove one of the alarm fuses, everything works like it should.also the alarm now doesn't work also...any suggestions on what's wrong? The remote doesn't communicate with the car also..
Instagram username:angelmkiv |
#1119 |
![]() Join Date: Nov 2011
Ever try installing infinite baffle 8's in the rear deck of an S14? Would remove the factory amps and torsion bars and bottom mount. Your thoughts are welcome.
Sub in question is here https://www.madisoundspeakerstore.co...r-cone-woofer/
S14 RB25 |
#1120 |
Bandwagon.
How do you remove dynamat?
- Hong Last edited by hOngsterr; 02-13-2015 at 11:33 AM.. |
#1121 |
![]() Join Date: Dec 2002
![]() Feedback Score: 39 reviews
Still doing custom work? Have not seen you post in a long time. Possibly interested in having a Racepak IQ3 installed into a s14 cluster.
1997 Nissan 240sx 1991 Nissan 240sx hatch |
#1123 | |||||
Sorry guys, I have not been on here much lately. I'm not a vendor on here at the moment and I have really been trying to get Broadfield Customs to a level where it makes me enough income that I can quit my day job.
Pull it off! Quote:
http://www.broadfieldcustoms.com/ https://www.facebook.com/BroadfieldCustoms http://instagram.com/broadfieldcustoms https://twitter.com/TobyBroadfield https://broadfield.wordpress.com Quote:
![]() As you can see in the next image, I also had a slight crease/buckle in front of the wheel arch: ![]() Also, that outer edge wasn't razor edge perfect when looking down the side: This is after body work and paint... 285 tire on a 18x11 wheel. ![]() ![]() ![]() |
#1124 |
Bandwagon.
nice update.
but it doesnt fully come off. so I've tried everything so im almost done with the rear hatch... mineral spirits/scotch brite/scrapers lol |
#1126 | |
Bandwagon.
But I meant my answer I found was to use mineral spirits and scrub/scrape away. Nice updates on your ride btw. |
#1127 |
AFC #1
I found the dry ice method works the best on dynamat and similar products. The film backed stuff chips off and the foil backed sticks to the foil then.
Sent from my iFad using Crapatalk
#1128 | |
Bandwagon.
So im straight up scraping the car and when it seems thin enough i scrub off with mineral spirits. |
#1129 |
![]() Join Date: Jan 2010
Hey broadfield, I think I'm gonna go about refinishing my shifter trim and cluster bezel (s13). Thing is it already has at least 2 layers of paint on it, when I first got the car I painted it silver, then about a year ago I painted it black again, but it was a half assed job and now it looks horrible. When I started sanding the paint just loaded up the sandpaper and I would get irritated, or I would use sandpaper so coarse it would show up in the finished product.
What would you suggest from start to finish? Sandpaper, primer, adhesion promoter, paint ect. I'm trying to get as close back to stock as possible. Thanks!
#1130 |
![]() Join Date: Oct 2007
Trader Rating: (53)
Do you know where to find a small fuse block with a 45A and another with a 75A fuse? I'm trying to clean up my fuse box relocation and i want to get rid of the factory fusible links and replace the current setup with something a little more compact installed where the air bag used to be.
#1132 | ||
The easier way would be to strip the paint with aircraft stripper or similar. The issue is, the stronger aircraft stripper will also melt the plastic if left on too long. However, weaker stripper may not get the paint off. So start with the better stuff and try not to let it sit too long. Sanding old paint off on a piece that has nooks and crannies, recessed switch mounts etc is a total nightmare. Some of my customers that get a cluster want to know if they can simply send me their other already painted interior pieces to color match. They say: "it should be no big deal to just sand the old paint off real quick and apply new, right!?!" I say: "you have no frigging idea how much work that is!" Hell, it would be 5 times cheaper to buy the parts new from Nissan than to pay me hourly to mess with it. Quote:
http://www.stingerelectronics.com/pr...&CategoryID=13 Absolutely!!!! |
#1133 | |
Trader Rating: (53)
![]() I'm looking for something that is capable of at least 12VDC @ 100A. The largest fuse of the two is only 75A but i want a holder that is rated a little higher for that safe zone. It doesnt have to be terribly pretty because I'm going to be mounting them to some plexi in place of the S14 airbag; they will be covered by the dash. Plus it will have to be able to take a smaller wire or ring terminal because those two wires actually arent terribly large. The rest of the fuses will be going to this since it is only rated for 30A per circuit: http://www.amazon.com/Blue-Sea-Syste...4ZC7Q4MBVAPWZW |
#1134 | |
#1136 | |
http://www.broadfieldcustoms.com/contact/ |
#1138 |
I was afraid I would get that response lol.. Oh well looks like I have something to do While I watch TV on the weekend. Also, what do you use for paint materials? I know finish with that SEM interior trim black stuff but do you spray any kind of primer down before that? Thanks!
#1139 |
Hey Broadfield, in your build thread you had car dollies to move your car to get painted when the subframes are dropped. I'm looking for some similar, where did you purchase them etc? Thank you so much!
#1140 | |
I used the ones from my friend's bodyshop. Not sure what brand they were... but they were sick! |
Tags |
broadfield, toby |
