Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 05-13-2013, 11:19 AM   #1
Mwaker
Mwaker's Avatar
Mwaker is an unknown quantity at this point
Help . . z31 revving in neutral w/out pushing pedal
I was heading back home today from the store. After getting on the highway, the Z started revving on its own without me putting any pressure on the pedal.
Then when I put the clutch in or placed the car in neutral, the car would rev up to 4K, once again without me placing a foot on the pedal.
Any ideas what could possibly by causing the problem.
86 Nissan 300zx T
Mwaker is offline   Reply With Quote
Old 05-13-2013, 01:42 PM   #2
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
Check your accelerator cable on top of the throttle body. Sometimes where the cable enters the protective cover, there are bits that can break and jam.
z31 Lovin'
http://imageshack.us/a/img337/2396/lowerit.jpg
DeleriousZ is offline   Reply With Quote
Old 05-13-2013, 06:09 PM   #3
Mwaker
Mwaker's Avatar
Thanks.
There was a piece of the protective covering that had broken off and looked to be getting stuck. I removed it from the cable and am about to find out if that solves the problem.
Old 05-13-2013, 11:48 PM   #4
Mwaker
Mwaker's Avatar
Problem solved. That was it. Thanks
300zx, neutral, revving, z31
