Sr acting funny
Okay, this is what Ive got...
S14 SR in S13 running 8lbs we just put it in and are trying to make it run right Use to: Hard start Idle like crap low vaccum would only rev up if you punched it would progressively run worse if you held it at a constant say 4-5k rpm RICH RICH RICH What I did: Checked ALL the sensors especially the maf all the piping for leaks, bov, ect.... replaced injectors(they were clogged, helped with the starting issue and rough idle some) set the timing Right now: Its Idling smooth, but its a little low vaccum is like 5-10in at idle, about 600rpm(seems too low to me) If I take it up to 1500rpm vaccum rises to about 15-20in which is where it should be at idle correct? you can roll into it slowly and it will hold 4k without hesitation If you roll into it a little faster it starts to get the hesitation it had before Anyone have any suggestions? This is my first SR and nobody in my area has done the 14 motor before, hence why Im here. Also, I only know enough to get myself by with vaccum and electical so if anyone has the pdf for the 14 vaccum lines or wants to explain where the lines under the tb go to what that would be a big help. I may have something crossed or plugged or vice versa that I shouldnt. Thanks!
![]() Sittin' Sidways Since 2007 |
went back out there to play with it some more.
Idling at 500rpm, 5in of vaccum Its running like this guys http://zilvia.net/f/s-chassis/210043...end-sight.html but with less vaccum and more boost
I made one of these, found a big boost leak. Vaccum went from 5in to about 15in and its Idling right around 1k. didnt get to see how it runs yet though, ran out of gas lol
IC Pipe Tester
