Old 05-22-2008, 01:53 AM   #1
Arauz
Arauz's Avatar
Arauz is an unknown quantity at this point
steering issues? what can this be?
Ok so here's what just started happening yesterday... I turn on the car and i hear a small whining sound coming from the belts or under it. I pull the throttle and the whine gets louder but not "LOUD". When I turn the steering wheel from side to side this whine becomes even more apparent but in an uneven noise pattern with what sounds like scraping metal. It's even affecting my belts because they fluctuate in rpm's with the turning of the steering wheel.
I replaced my rack and pinion a month ago with jeorge. (JG)
What can this be? and can it be dangerous to drive?
Thanks guys for any ideas.
Arauz is offline   Reply With Quote
Old 05-22-2008, 10:35 AM   #2
deuceforty
deuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of light
powesteering pump.... not enough fluid or dying pump, maybe a loose belt
TWO TONE COUPE FS NC
deuceforty is offline   Reply With Quote
Old 05-22-2008, 06:24 PM   #3
got boost??
got boost??'s Avatar
got boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura about
power steering pump for sure. check your fluid. if its full its time to buy a new pump. lucas power steering fluid/stop leak can help too
got boost?? is offline   Reply With Quote
Old 05-23-2008, 02:16 AM   #4
Jbma327
Trader Rating: (51)
Jbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really nice
Feedback Score: 51 reviews
KEEPIN IT REAL!
Jbma327 is offline   Reply With Quote
Old 05-23-2008, 03:02 AM   #5
GSXRJJordan
GSXRJJordan's Avatar
Yup yup P/S pump. You need to check fluid levels, most likely they're low. The noise you hear is air in the pump/lines.
