Old 03-04-2015, 12:24 AM   #1
aga
aga's Avatar
aga is an unknown quantity at this point
external wg housing on t28, with 44mm wg, will it fit?
hi folks. i'm thinking of switching to this housing http://www.himni-racing.com/turbocha...t2871r-gt2876r
on my 2871R ,using the stock manifold. will the 44mm external fit directly on the turbine, or will i have to use a 90deg elbow between turbo and wastegate to position it elsewhere so it won't hit the frame? anyone got any photos of such a housing installed? i think i've seen one but it may had 38mm wastegate which is a bit smaller.
My Build
aga is offline   Reply With Quote
