Old 10-19-2011, 02:30 AM   #1
XiaoAZN
XiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-known
S13 Fog Lights
So I followed this tutorial on wiring up my fog lights:
HOW TO: S13 Fog Light Wiring : 240sx General Discussion
My lights worked for about 5 seconds, but now when I try and turn them on, 15a FR Fog fuse continuously blows. (The fuse in the drivers side fuse box)
I'm using an OEM fog light switch and I also have the blue relay. The wiring harness on my lights are also soldered correctly so I don't think it's shorting on my wiring harness.
What could be causing the fuse to keep blowing? I'm guessing a short, but do you guys know where it might be?
XiaoAZN is offline   Reply With Quote
Old 10-20-2011, 03:38 AM   #2
c.boots
c.boots's Avatar
c.boots is an unknown quantity at this point
I had the same issue when i hooked up my 180sx/chuki foglights up to the factory harness.
What i found out was one of the wires was grounding out inside the housing of the foglight causing it to blow the fuse.
<img src=../../i871.photobucket.com/albums/ab280/geboe/winding_road_10.html border=0 alt= />
c.boots is offline   Reply With Quote
Old 10-20-2011, 03:22 PM   #3
XiaoAZN
Sorry, I'm pretty new to all of this electrical stuff. What do you mean by grounding inside the housing, and how did you fix it?
Old 11-20-2011, 11:59 PM   #4
Sr20Developer
Sr20Developer is an unknown quantity at this point
You will have to take apart the fog light itself and check for any exposed wires or connectors. I had the same problem with the fog lights on my car and i had to open them both up an wrap the connectors with electrical tape. Are you using oem or aftermarket lights
Sr20Developer is offline   Reply With Quote
