Old 07-09-2012, 04:05 PM   #1
Hyozan
Hyozan is an unknown quantity at this point
5 lug help
Besides buy hubs from a 14 or buying after maket hubs, I wanted to no if hubs from a z31 or z32 will work. Please don't bash on me
Hyozan is offline   Reply With Quote
Old 07-09-2012, 04:42 PM   #2
revsx
revsx is an unknown quantity at this point
z32, j30 and maybe even q45 will work.
revsx is offline   Reply With Quote
Old 07-09-2012, 05:03 PM   #3
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Are you talking about the front? If so, there you can source OEM S14 hubs (direct bolt on if you have a s14)if you have a s13 you will need s14 lca iirc. You can buy cheap china hubs in which the bearing will go out on you in less than 6months. Z32 fronts will not work. Heck if your ghetto enough you can always re-drill your 4 lug hub and add the extra stud. I've see people do it, not suggested.
For the rear you can source z32 NA rear or s14 oem rear or conversion hubs. Q45 is too big like the z32 TT so axles will not fit.
J30 read this: http://zilvia.net/f/s-chassis/362537...-lug-hubs.html
And if you don't want to get bashed on for being LAZY and being a NOOB, USE the SEARCH function, I found that in less that 15 seconds using GOOGLE.
eek is offline   Reply With Quote
Old 07-09-2012, 05:50 PM   #4
Hyozan
It's for an s13 an i need some for all around. 14 hubs arw hard to find so that's why I ask
Old 07-09-2012, 07:41 PM   #5
Sileighty_85
Sileighty_85's Avatar
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-10-2012, 05:32 AM   #6
jrob08
jrob08 is an unknown quantity at this point
I've done research because I have a 13 hatch and have see. That j30 hubs will work the only thing needed is a shop with a press
jrob08 is offline   Reply With Quote
Old 07-10-2012, 05:16 PM   #7
purplove
purplove's Avatar
purplove is an unknown quantity at this point
^^No fkn shit, do yourself a favor and search. This has been covered 343728947238947239743289749 times.
purplove is offline   Reply With Quote
Old 07-10-2012, 07:42 PM   #8
eek
How are s14 hubs hard to find? People part out their cars all the time on here and craigslist. If you don't want wait go online and find one of the many online dealerships or a local dealer and order some new ones so you don't have to worry about your wheel bearings going out. If you don't have the money to buy new stuff for your car how are you going to afford new 5-lug brake rotors and rims to put on your newly 5-lug swapped car? All the info your seeking has been covered, you just need to spend some time to search and find your answers.
Swear kids these days lazy and dumb as fuk.
Old 07-11-2012, 04:46 PM   #9
jcruz85
jcruz85's Avatar
jcruz85 is an unknown quantity at this point
YouTube - 89-94 S13 / 240sx Silvia Front 5lug MOD
Here this should make things simpler...tried looking for something on the rear but didn't find anything. Some people learn by seeing not reading.
jcruz85 is offline   Reply With Quote
