Old 04-06-2010, 10:34 AM   #1
240_s14
240_s14 is an unknown quantity at this point
clutch acting weird!
Alright im kinda new to 240sx, i just bought a s14 with a redtop sr20 and my clutch seems to be slipping, but i get no smell of burnt clutch at all and it only slips when temperature is hot (outside)! i asked the previous owner and he said he jus bought that clutch bout 2k miles ago and its the fx400 from clutch masters. what do u guys think maybe causing this? could it be the clutch needs adjusted?
240_s14 is offline   Reply With Quote
Old 04-06-2010, 10:45 AM   #2
Drift N Dragg
Username Monster!
Drift N Dragg's Avatar
Drift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud of
What was the Condition of the Flywheel?
Have you Tried Bleeding the Clutch Lines and Clutch Master Cylinder?
Is the Clutch Damper still installed on the Vehicle?
More so disgusted. Much like how a dog owner reacts when they notice a dog about to eat some shit off the ground because the dog thinks its a good idea.
2015 Subaru STI
1997 Mitsubishi Eclipse GSX
A Ton of Projects
Drift N Dragg is offline   Reply With Quote
Old 04-06-2010, 10:55 AM   #3
240_s14
flywheel was replaced along with the clutch from clutch masters also...i bled the clutch lines and i got a lil diffrence, but jus yesterday it started slipping and i revd it and did a small burn out and clutch grab good! til the next 2 blocks it started slightly sliping again.
