Old 12-03-2013, 12:55 PM   #781
AE_Racer
AE_Racer is an unknown quantity at this point
Originally Posted by Dolph_KYAS13 View Post
Got off my ass and made myself a coil pack cover to match the valve covers. (sadly HKS only ever offered it for SR motors)
I still need to sand down the tooling marks and paint it wrinkle black. Anodized Purple HKS oil cap is also on the way to complete the look
-Jordie
Can't share how you did the valve covers with the whole class? Lol i'd love that on my rb. awesome job on the plug cover too.
http://tougestars.net
AE_Racer is offline   Reply With Quote
Old 12-11-2013, 06:26 AM   #782
JF_OverBoosted
JF_OverBoosted's Avatar
JF_OverBoosted is an unknown quantity at this point
-Jordie
That sir is f***in CLEAN & legit AF.
Good job bro.
JF_OverBoosted is offline   Reply With Quote
Old 12-22-2013, 10:11 AM   #783
silviaks2nr
silviaks2nr's Avatar
Old 12-22-2013, 11:24 AM   #784
MeSs
MeSs's Avatar
MeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura about
My CA18DET valve cover with custom spark plug cover Sorry for Instagram blurryness.
Since no aluminum spark plug cover is made except the silly expensive HKS Power, one I made it myself. The reason I wanted aluminium is that I wanted the same powdercoated finish on the spark plug cover as the valve cover.
Sparkplug cover is 2pc, made with angle grinder, power drill and a electric handsaw. No CNC.
2011 BMW F11 5-series and 2003 Nissan 350Z
MeSs is offline   Reply With Quote
Old 12-22-2013, 11:32 AM   #785
Dolph_KYAS13
Dolph_KYAS13's Avatar
Good job bro.
Thanks Buddy
Alright Class,
I've had numerous PM's about how I did this. To be completely honest, it wasnt hard at all it just took patience and planning.
First I made an illustrator file for the shapes of the livery. It was damn near impossible to find a good pattern in high resolution but after searching forever I found someone had created and traced it in Illustrator.
I had the Shapes cut out in low tac vinyl at a local signage shop.
To prep the covers themselves, I sanded them down to remove the factory casting marks so the vinyl stencils would adhere and paint would not bleed.
I used zinc chromite primer (read the label follow the instructions) and primed the sanded valve covers.
First colour to go on was the red, I then used pin stripe tape to mask the red lines. The paint used was just Kylon spray paint I bought at Canadian Tire but im pretty sure its available at walmart in the states.
Once the red was all masked, I painted the covers purple. After leaving it to try overnight (there is a lot of waiting) I used the stencils to mask the purple part of the livery.
It was just a matter of repeating the steps with the green, applying the stencils and then painting the whole thing black.
Once dry, carefully peel off the stencils. This is the best part as all the waiting pays off. After all the stencils were removed, I sprayed a thick coat of clear over the everything.
Like everything else painted, its all in the prep-work. I used regular primer at first and it did not adhere to the aluminum. Take your time and make sure everything is 100% dry between coats and stencil application and it should work out just fine.
-Jordie
-Jordie Lewis
'93 Skyline Type M
Old 12-22-2013, 11:37 AM   #786
Dolph_KYAS13
double post.
-Jordie Lewis
'93 Skyline Type M
Old 12-22-2013, 08:09 PM   #787
slideways40
slideways40 is an unknown quantity at this point
shitty cell phone pics but you get the picture
slideways40 is offline   Reply With Quote
Old 12-25-2013, 01:02 AM   #788
KAs14slider
KAs14slider is making a name for him/her selfKAs14slider is making a name for him/her selfKAs14slider is making a name for him/her self
That is so funny. I recently got my timing and spark cover done.
Corndrift Blog
KAs14slider is offline   Reply With Quote
Old 01-03-2014, 11:06 AM   #789
AE_Racer
Thanks Buddy
Alright Class,
-Jordie
I'm not very creative at all so that was an awesome write up. Thank you!
Old 01-03-2014, 01:51 PM   #790
conrad_s13.5
conrad_s13.5's Avatar
you guys must be good at working wood
cONtRol FReAkS
Old 01-03-2014, 05:08 PM   #791
ILoveJDM
wood?! are you guys not scared it will catch fire?!
DODOlogic.ca
Old 01-03-2014, 05:18 PM   #792
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
^Its Hydro dipped
This is all Hydro dipped right? great work! More pics on the IM?
PeaceOnesxWai is offline   Reply With Quote
Old 01-03-2014, 05:56 PM   #793
silviaks2nr
Yes It's all hydro dipped. I put a candy black coat + clear over it to give it more depth. I don't have anymore that I took but these are after a test mock up on the owner's motor:
Old 01-03-2014, 06:21 PM   #794
ILoveJDM
Originally Posted by PeaceOnesxWai View Post
^Its Hydro dipped
I guess if you soak the wood in water it won't catch fire.
DODOlogic.ca
Old 01-03-2014, 09:56 PM   #795
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
Ah, finally this all makes sense now.
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 01-03-2014, 10:23 PM   #796
flatout
flatout's Avatar
flatout is an unknown quantity at this point
My motor about to be going in the car
Sent from my SCH-I545 using Tapatalk
flatout is offline   Reply With Quote
Old 01-04-2014, 07:36 PM   #797
tricky_ab
tricky_ab's Avatar
Old 01-08-2014, 08:17 AM   #798
shift0246
shift0246 is an unknown quantity at this point
that hks logo is sicc!!
shift0246 is offline   Reply With Quote
Old 01-08-2014, 08:26 AM   #799
Michaelwinne
Michaelwinne's Avatar
Michaelwinne is an unknown quantity at this point
Damn dude your SR looks badass.
Michaelwinne is offline   Reply With Quote
Old 01-08-2014, 08:44 AM   #800
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I'm the world's biggest fan of keeping it plain, or "oem+" but I gotta admit that valve cover looks fantastic with that CF dip on it. Super well done man. I dig it!
Old 01-08-2014, 10:35 PM   #801
silviaks2nr
Thanks Cody!
Old 02-02-2014, 09:53 AM   #802
240Lover770
240Lover770 is an unknown quantity at this point
can finally post here. bay is same color
240Lover770 is offline   Reply With Quote
Old 02-02-2014, 12:03 PM   #803
feito
feito's Avatar
i riced it up
Old 08-21-2014, 07:53 PM   #804
krron
krron is an unknown quantity at this point
Here's mine painted by me
krron is offline   Reply With Quote
Old 08-21-2014, 08:46 PM   #805
jerry_beans
jerry_beans is an unknown quantity at this point
*correction
An s14 one like this just sold here in Texas. Yokoi brought it with him to the fabricated motorsports drift event. I was trying to buy it.
IG @jerry_beans_
jerry_beans is offline   Reply With Quote
Old 08-21-2014, 08:52 PM   #806
jerry_beans
Aaron losey bought it
IG @jerry_beans_
Old 08-22-2014, 03:27 PM   #807
boriksh
boriksh's Avatar
boriksh is an unknown quantity at this point
here is mine
boriksh is offline   Reply With Quote
Old 08-22-2014, 05:14 PM   #808
tricky_ab
tricky_ab's Avatar
That's really cool! I'd like to get one, but I'd have to order it directly...
He should have brought more haha!
Instagram
Old 08-23-2014, 12:02 PM   #809
ziptie
ziptie is an unknown quantity at this point
im planning to get one when i go to Japan in April ^^^^^
@billiebillay
ziptie is offline   Reply With Quote
Old 08-23-2014, 02:05 PM   #810
ehhhregartless
www.zeedakay.com
IG: @zeedakay
