Old 05-25-2009, 01:33 PM   #1
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
STupid rear Coilover question
When Mounting rear's on a S14 (new to the S14 somewhat) Pictured has a Black Spacer type peice at the very bottom on the rear coils where it goes into the "stud" on the rear LCA.
What side is the Black spacer supposed to be on.The inside w/ the washer or the Side facing the wheel itself.Wanna make sure I've got it right.This is the 3-4 set of coils on all the cars I've owned but damn I can't remeber how it suppsosed to be COrrect.
The S14 uses a Bolt @ Big round Washer to go through it (STud),..the S13 uses a Nut & Round washer that goes on the bolt coming out of the rear LCA
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 05-25-2009, 01:40 PM   #2
Killa_D
Killa_D's Avatar
Killa_D can only hope to improve
the flat part facing the wheel and the other long part facing the washer.
Killa_D is offline   Reply With Quote
Old 05-25-2009, 06:48 PM   #3
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
No. The long part should be toward the wheel, it's a spacer to prevent the coilover from rubbing on the LCA. Some brands of coilover come with a separate spacer.
Check out my mad tyte ms paint skilz yo.
HYPNOTIK is offline   Reply With Quote
Old 05-25-2009, 10:43 PM   #4
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
yes hypnotik is right the long part is facing toward the wheel.
godsmack is offline   Reply With Quote
Old 05-26-2009, 03:29 AM   #5
HYPNOTIK
HYPNOTIK's Avatar
I know I'm right, shut the f*ck up.
Old 05-26-2009, 05:39 PM   #6
godsmack
godsmack's Avatar
you're just jealous cause i can skate at work and you can't.
now go learn how to drive.
Old 05-26-2009, 09:49 PM   #7
Kiwi
Kiwi is an unknown quantity at this point
i can feel trouble a-brewin
Kiwi is offline   Reply With Quote
Old 05-27-2009, 03:58 AM   #8
HYPNOTIK
HYPNOTIK's Avatar
I believe your the one that needs to learn how to drive. How many trannys have you been through now?
Old 05-30-2009, 10:35 AM   #9
clv5045
clv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymore
the spacer also helps the shock be aligned correctly and straighter to the top mount so yes it should be facing the wheel.
91 240 cpe w/ sr SOLD
96 240 w/ sr
clv5045 is offline   Reply With Quote
Old 06-01-2009, 09:17 PM   #10
godsmack
godsmack's Avatar
You're just jealous that my car is strong enough to break the tranny's.
Old 06-02-2009, 09:08 AM   #11
kalypso123
(ノಠ益ಠ)ノ彡
you guys are hilarious
Old 06-02-2009, 09:39 AM   #12
S14DB
AFC #1
S14DB's Avatar
It should only bolt on with the spacer facing out. The stud on the knuckle is tapered.
