Old 04-12-2008, 04:27 AM   #1
threats14
threats14 is making his/her stupidity well-knownthreats14 is making his/her stupidity well-knownthreats14 is making his/her stupidity well-known
S13SR into S14 problems.
1st problem.
S13 SR20DET from JDM-Online.com into S14 Chassis.
-Motor cranks healthy.
-No spark coming from each spark plug.
-No fuel coming through the lines.
-Starter was tested and it spins.
-Dash & Radio works fine.
-Followed the s13SR to S14 wiring harness write up. Word for word. The same write up everyone's been using on Zilvia/Nico.
-New battery.
What could be wrong?
2nd problem.
-S13 Transmission isn't accepting my S14 non-abs driveshaft.
-At one point, the output would be jammed up in the transmission and would be a bitch to pull back out.
Any idea?
threats14 is offline   Reply With Quote
Old 04-13-2008, 12:30 AM   #2
Slow Poke
Slow Poke's Avatar
Slow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really nice
Was your car auto before? If not then the DS should work just fine. You will have to take the dust collar off the end of the trans.
Slow Poke is offline   Reply With Quote
Old 04-13-2008, 08:39 AM   #3
threats14
Nah my car was always 5 speed..
The DS will go, but it'll jam up within the spines or sometin.
Must be the angle the splines are lining up in, I guess.
Anyone ever come across a thing called "TWISTED SPLINES" in the transmission?
Old 04-14-2008, 01:22 AM   #4
SRzenkiS14
SRzenkiS14's Avatar
SRzenkiS14 is an unknown quantity at this point
haha i had the same shit man! i have a 95 s14 and i did a redtop swap. First the driveshaft, you really have to shove it in there, it will be fine, but it feels like its jamming but its not. Lube it up and stick it in there, when it gets stuck the someone else to hold the end of it while you take a 14mm wrench and turn it clockwise. have your buddy twist and push. Its hard but it works. Second, your starting problem. i had the same issue w/ the new battery, healthy crank and such. your fuel pump is not turning is caused by bad connection to ecu, no fuel coming in is also a result of that. Best suggestion is send your harness out to get it fixed. sometimes your o2 sensor can fry your harness.
SRzenkiS14 is offline   Reply With Quote
Old 04-18-2008, 11:56 PM   #5
threats14
Alright update.
Thanks SRZENKIS14. Lubing up the driveshaft worked fine and didn't take that much time to shove in there. Hahaha. Thanks a bunch man.
But one more problem stalls.
SO THE ECU is fine. And the wiring write up we used was the same S13SRintoS14CHASSIS write up everyone's been posting up on ZILVIA.
WTF IS GOING ON?!
Old 04-19-2008, 12:31 AM   #6
harangatang
harangatang's Avatar
harangatang can only hope to improve
wiring..
or the igniter chip
if you can, trade the igniter chip out with someone elses that you know works
idk about the fuel pump
harangatang is offline   Reply With Quote
Old 05-02-2008, 11:04 AM   #7
eligido21
eligido21 is an unknown quantity at this point
Send a message via AIM to eligido21
did you ever figure out the first problem? i am having the same exact problem with my s13 sr into my s14.
eligido21 is offline   Reply With Quote
