Old 03-06-2012, 12:46 AM   #181
nyquil_2
nyquil_2 is an unknown quantity at this point
Why soo low on power with C16???
I made almost the same power as you but on 93 octane and a KA24de....
nyquil_2 is offline   Reply With Quote
Old 03-13-2012, 08:22 AM   #182
alcolade
alcolade is on a distinguished road
Got some stuff welded up this weekend for the intercooler.
Also got the paint on the coil cover.
alcolade is offline   Reply With Quote
Old 03-13-2012, 03:33 PM   #183
CDD200
CDD200 is an unknown quantity at this point
has anyone tried to pull just the trans(r154) after it has all been installed, i think my fw bolts have come loose, hate to pull motor and trans.....
93 s13 coupe 5 speed- Ls2 swap in the works
97 sc300-gte/v160
CDD200 is offline   Reply With Quote
Old 03-13-2012, 06:24 PM   #184
bullfrogg0
bullfrogg0's Avatar
bullfrogg0 is an unknown quantity at this point
Best bet is gonna be to pull motor and trans as one piece
bullfrogg0 is offline   Reply With Quote
Old 03-13-2012, 06:44 PM   #185
JDM SPUG
JDM SPUG is an unknown quantity at this point
I pulled just the trans out after i did my swap because when I went on my first test drive i found out the clutch was done. So yes you should be able to pull just the tranny.
JDM SPUG is offline   Reply With Quote
Old 03-13-2012, 07:20 PM   #186
alcolade
I'd say maybe loosen the front subframe bolts as well as motormounts depending on if you have solid mounts or what. Should make it easier to get to.
Old 03-13-2012, 07:31 PM   #187
Flicktitty
Flicktitty's Avatar
I'm guessing the massive amount of tire spin made the dyno read alot lower then it should have.
Old 03-13-2012, 07:50 PM   #188
JDM SPUG
did you bring that to a body shop to get painted?
Old 03-14-2012, 05:20 AM   #189
alcolade
A buddy owns a shop and his painter offered to do it. Its black with gold and prism flake on it. That flake is going in the engine bay and interior as well, just over a different color. should make it show alot more once everything is done.
Old 03-15-2012, 09:36 AM   #190
HiI'mDustin
HiI'mDustin is an unknown quantity at this point
Most people have seen my thread on other forums but Ill add to this one as well
Running a little rough
http://www.youtube.com/watch?v=_S82BNL_zSQ
Mods
Engine
2jz-GTE
Chase Bays Harness(Still working through it)
Chase Bays Power steering kit
Ebay radiator
4.75 in thick Skyline R34 intercooler with custom piping
Tial BOV
Aeromotive Fuel pump
Custom exhaust
Suspension/brakes
5 lug conversion
Evo 9 Brembos with rotors for front
Q45 rear calipers and rotors
ARP Studs
HPS Pads all around
Stance Gr+ Pro coils
Spl rear upper control arms
Spl rear traction rods
Spl rear toe arms
Spl tension rods
Spl lockout kit
Spl Solid Subframe bushings
Spl Solid diff bushings
Drivetrain
R154
6 puck act clutch
findanza lightend flywheel
Q45 rear diff
300zx TT Drivers axel
Q45 pass axel
Exterior
silvia front end with bricks
Supra TT wheels
HiI'mDustin is offline   Reply With Quote
Old 03-19-2012, 06:10 PM   #191
aled
aled's Avatar
aled is an unknown quantity at this point
Those of you with 2J swaps into S14's or even S13's for that matter, ever had any clearance issues with your hood?
My 1.5JZ is much taller than my old 1J, and now my hood won't close. I have the Zerolift engine mount brackets. I'm skeptical to try and lower the engine any more, I don't want oil pan sitting lower than the sway bar.
aled is offline   Reply With Quote
Old 03-19-2012, 06:29 PM   #192
nsain
nsain is an unknown quantity at this point
I have a 2jz in a s14 and mine barely clears, using eBay mounts. I remember someone saying something about how they had to shave their rubber mounts or something to clear theirs, but I think it was an s13 with a na.
nsain is offline   Reply With Quote
Old 03-19-2012, 11:19 PM   #193
jdm2191
jdm2191's Avatar
Trader Rating: (79)
jdm2191 is an unknown quantity at this point
Feedback Score: 79 reviews
What intercooler is that?
My Build: The "Coupe De Ville" 1JZ Build!!
jdm2191 is offline   Reply With Quote
Old 03-20-2012, 04:57 AM   #194
alcolade
Its a Hybrid Dynamics or something that i just the ends on and had the long 90s welded onto it. Mostly shit i had laying around from previous setups.
Old 03-20-2012, 07:19 AM   #195
HiI'mDustin
Pretty sure my oil pan sits below my subframe.
Old 03-20-2012, 07:38 AM   #196
babillaracing
babillaracing is an unknown quantity at this point
mines sits pretty even with the cm (custom made mounts though)
618 whp tuned by alpha
babillaracing is offline   Reply With Quote
Old 03-20-2012, 07:55 AM   #197
waste_of_space
waste_of_space is an unknown quantity at this point
Traded my friend my SR for his near complete aristo 2jz swap. Just need wiring, and still waiting on mounts/driveshaft/shifter extension from turbo dave. That guy is wayyyyy too slow, not sure how he stays in business.
Ordered all new valve cover stuff yesterday. Gonna do the timing belt/front main/rear main/valve cover gaskets/pulleys and everything while I continue waiting for the swap mounts. Got all the stuff I need to make the exhaust with a fancy decat too.
Can anyone say for sure which radiator hoses they used when running a KA radiator? If not I can just mock up/get rubber hoses, but was looking to get some silicone ones.
waste_of_space is offline   Reply With Quote
Old 03-20-2012, 08:38 AM   #198
Henrietta82
Henrietta82 is an unknown quantity at this point
Such a great info.! I am in the process of swapping in a 1jz vvti. The heater hoses cleared some confusion and so does the p/s line.
Henrietta82 is offline   Reply With Quote
Old 03-20-2012, 10:44 AM   #199
aled
aled's Avatar
If you need a 2J Aristo Wiring Harness/ECU, I have one. Shoot me a PM.
I used a MKIII Supra Lower Samco Hose.
For the upper, I cut the curve out of the upper water neck and made a custom hose to connect.
Super easy.
Old 03-20-2012, 11:16 AM   #200
Flicktitty
Flicktitty's Avatar
i used a MKIV Supra lower radiator hose, just needed to shorten it up a bit. I also cut the waterneck off and just ran to oreillys and found a hose, i'll grab the part number today.
Old 03-20-2012, 02:19 PM   #201
waste_of_space
Okay thank you guys!
I have the ecu and the harness, just gotta go about splicing the KA harness into it so everything else is still functional lol. Though I think my friend said one of the 3 main plugs was missing or something? The engine and stuff is sitting at my friend's house currently, but I'll take some pics of it when I swing by and do all the gaskets and stuff.
And on a random note, has anyone ever tried moving that exhaust restriction valve to control boost? I'll be running straight exhaust, but don't want crazy high boost levels because of it, so I was thinking I could build some sort of "stop" for it (almost like a throttle pulley stop) so that way it leaves it open some, but not all of the way, if that makes sense.
Edit: nevermind, that was probably a dumb question haha. I assume restricting the airflow would only control boost to the rear turbo but the front one would still be pushing more than I want it to lol
Old 03-21-2012, 06:53 PM   #202
CDD200
here is how mine turned out, now i just need some body work and paint, ha ha
97 sc300-gte/v160
Old 03-21-2012, 06:58 PM   #203
JDM SPUG
HiI'mDustin
Did you have to modify anything to make the Q45 rear diff work other than the axles?
And if so what did you do?
Old 03-21-2012, 08:38 PM   #204
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Sorry for the late replies. Yes, the car lost a lot of power due to spinning on the dyno, haven't been back to see what it'll do now.
As for pulling the trans, you have to loosen/drop the front subframe and lower the engine a little. This allows you to get to the top bolts and turn the trans to pull it out. It's a whole lot easier than pulling everything together, and you shouldn't have to take your harness off or anything else for that matter.
Video of the cars recent runs. A 2 step will help tremendously and I'm looking to get in the 10's on the r154 before switching to a powerglide and spraying it.
s14 2.MOD - YouTube
http://www.youtube.com/watch?v=FTlgDdygb-A
http://i98.photobucket.com/albums/l258/Deftec/signew-1.jpg
Deftec is offline   Reply With Quote
Old 03-21-2012, 08:57 PM   #205
Flicktitty
Flicktitty's Avatar
not a bad mph on that run. get some better tires or try really launching it and see what it will do. It's getting there man, Nice to see some of the "og" JZ swappers still around.
Old 03-22-2012, 08:12 AM   #206
HiI'mDustin
HiI'mDustin
Pretty much need the diff and the axles.
Drivers side from a TT 300zx is def the hardest part to find.
Also the companion flange is different so you will have to modify it or get a custom driveshaft.
Old 03-24-2012, 12:52 PM   #207
DallasTXjdm
DallasTXjdm's Avatar
Trader Rating: (41)
DallasTXjdm is an unknown quantity at this point
Feedback Score: 41 reviews
Thumbs up
Flicktitty - Awesome thread in which it has been a great help with my build! Thank you!
JDM SPUG - digging the paint job on the valve cover! can't wait to see how the rest of the car turns out!
waste_of_space - Man before you know it your complete project will be stacked up and ready to go in that pile! I bet you're ecstatic! lol
aled - Thanks for the info you PM'd! I appreciate it bro!!!
CDD200 - Do you have any larger pictures of your engine bay? Which intake manifold is that?
Deftec - Are you going with methanol inject? If so, which kit are you looking at? Sweet MPH by the way that's definitely 10s right there. What was your 60' and what tires were you running?
HiI'mDustin - How are you liking the SPL suspension?
DallasTXjdm is offline   Reply With Quote
Old 03-25-2012, 08:18 AM   #208
waste_of_space
Yessir! Got my mounts and shifter extension yesterday! All that's left is the driveshaft! Found a good lead on a harness so that's taken care of as well (:
Anyone else have trouble breaking their crank pulley loose?! Lol
Today I'll be doing the timing belt/tensioner/front&rear mains/cam seals/ valve cover gaskets and swapping the waterpump out and dropping the motor in!
Old 03-25-2012, 12:23 PM   #209
Deftec
No meth. That's on c16 and 23psi. My 60' times sucked ass(2.0 was my best) and I'm on 255 BFG's. It'll be getting a powerglide/spray/bigger turbo soon, so hopefully it'll be in single digits with some decent tires by then.
For hoses, I used the KA lower hose and cut the end off a little. The upper hose you can use an IS300 hose.
Old 03-26-2012, 07:09 PM   #210
CDD200
Dallas-idk how to make them any bigger, anyone that could help, is it something i do here or with photobucket??
stock intake just cleaned and clear coated
97 sc300-gte/v160
