Old 05-23-2012, 11:58 AM   #31
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
Awesome! Glad this popped up. I need to rebuild my 240 calipers! I figure the procedure is very similar?
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 05-23-2012, 12:07 PM   #32
Briou
Briou's Avatar
Briou is an unknown quantity at this point
If I had to guess I would think it would be similar...
Briou is offline   Reply With Quote
Old 06-09-2012, 09:52 PM   #33
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
Thumbs up
Nice Job on getting the rebuild done.
I suggest to anyone who doesn't have a compressor to not use any tool within the inner walls of the pistons. If you can get the tool on the outside of the piston and pull it out then that will save you from damaging the walls of the pistons..
I found through trial an error the best way to pull the pistons out without a compressor is using the following tools and method:
A long flat head screw driver and or small crowbar, cardboard, and 1 C-clamp (4 in or bigger).
You will need a table of some sort to lay the caliper half on and you will then C-clamp the caliper half to the table ( this way the caliper will not move at all). The pistons should be facing down towards the table.
Use the cardboard on the clamp side that goes to caliper so it doesn't scratch or damage your paint or the caliper itself. You then take a flat head screw driver or small crowbar and put it on the lip of the piston (using the caliper for torque) you push down and the piston will slide out. If it does not slide out or gives your trouble, you can push down 1 side of the piston at a time and you will be able to slowly shimmy it out.
The screws can be torqued to 60 pounds.
If you don't have grease you can use brake fluid to lube the pistons / seals when you push them back in.
The stages of my rebuild:
Dorifto Machine is offline   Reply With Quote
Old 06-19-2016, 03:02 PM   #34
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (30)
Nissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura about
Feedback Score: 30 reviews
Hello i was wondering if the bad assembly clips are 100% necessary?
Not the ring and top spring, the clips that go on the back of the pads and meets the pistons
Nissan2nr22 is offline   Reply With Quote
brake, rebuild, seals, z32
