Old 05-30-2013, 08:16 AM   #1
luiss14
luiss14 is an unknown quantity at this point
s14 plz help me wit my s14
so im having charging issues my batt light is on. the car is running off my battery i have a read top optima i have tested the alt and its reads 13v correct me if im wrong but isn't it suppose to be sending out 14v?? if so with that one volt lost could that be my issue my battery is in my trunk... plz help idk what else to do
Where Dey Do Dat At
luiss14 is offline   Reply With Quote
Old 05-31-2013, 09:39 PM   #2
olskoolgamr
olskoolgamr is an unknown quantity at this point
Charging voltage should be around 13.8 to 14.8 volts. Any lower send the alternator to autozone to get tested for free, check ur draw on the charging system wires as well draw should be no more than .02 for each wire.
-GSpeed4ever-
olskoolgamr is offline   Reply With Quote
Old 06-01-2013, 11:24 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
What voltage are you seeing at the battery with the car running?
CLICK HERE!!!
Old 06-01-2013, 02:48 PM   #4
luiss14
It's staying steady around 11.50 don't kno it's data cuz it's a strong batt I l didn't really see a draw
Where Dey Do Dat At
Old 06-01-2013, 03:31 PM   #5
Kingtal0n
Kingtal0n's Avatar
Optima is one of those batteries that even when dead will put out good voltage. You need to check if the alternator is good, because that is usually what triggers the light on the dash. With the engine running, the voltage at the battery should significantly be higher than it is when the engine is not running. If you detect (via voltmeter) that there is no change when the engine is running, the alternator is either bad, or connected incorrectly.
https://tinyurl.com/turbo240
Old 06-01-2013, 11:06 PM   #6
Sileighty_85
Sileighty_85's Avatar
If you properly tested the alt and your getting 13+ volts your alt should be fine.
however if you are getting 11.50 at the battery while its running then you have an issue between the alt and battery.
you can also do the ghetto alt check my disconnecting the NEG battery cable while the engine is running and if it stays running then the alt is fine.
Of course some ppl with flail thier arms saying ooohhh youll short the diode in the alt by doing that... it kinda depend on design for that but Ive done it to 40+ times and never had an issue.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-01-2013, 11:13 PM   #7
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
What gauge wire are you using?
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
