Old 06-18-2008, 05:59 PM   #1
BustedS13
BustedS13's Avatar
the "$30" Ghetto Lojack thread
Meet BloJack(tm).
i put the $30 in quotations because you're really looking at about 60 with tax and all that, plus phone prices have gone up. maybe if you find some old ass phone on craigslist you could do it for $30, but i'll be using new shit.
i know this has been discussed in other threads, but i feel it should have its own thread, especially considering how jam packed the stolen goods forum is.
Ghetto Lojack. you take a Boost Mobile GPS-enabled phone, load some software onto it that allows you to track the phone on your computer, and then leave it on and charging in your car. every 90 days you'll need to add minutes ($10 worth? unclear at this point).
you'll need:
-Boost Mobile GPS-enabled phone (Target sells the i425t for 39.99)
-mini-usb cable (to load the software to the phone. you probably have one for a digital camera or another phone or an mp3 player or whatever. if you don't, you have a friend who does, so don't buy one)
-car charger (you can get a mini-usb car charger at walmart and anywhere else for under ten dollars)
-add-on 12v plug (hardwire in your car to plug this thing in)
you'll need to download software from:
http://www.mologogo.com/
to use on your phone. load it up, set it up, and turn it on. the phone has to be on with the application running at all times, so you'll want to hardwire that in your car in a discreet location. then you can track your car when it gets jacked on the website. the end.
i'll update with my own experience when i set this up with the i425t.
here are some threads on other forums about this setup.
http://www.xtremesystems.org/forums/...d.php?t=154516
http://honda-tech.com/zerothread?id=2058648&page=1
and here's the phone i'll be using. it has a nice flat back just begging for some velcro.
i'll pick this phone up in the next few days and rig it up for use, see how long the battery lasts without being plugged in so i can decide between constant power or accessory power, and so on and so forth.
Old 06-18-2008, 06:01 PM   #2
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
++1 hahahha Coo shit
S13Boosts is offline   Reply With Quote
Old 06-18-2008, 06:07 PM   #3
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
that's actually a pretty nice looking phone. might consider doing this too.
how well does this work btw? does it show realtime tracking?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 06-18-2008, 06:09 PM   #4
BustedS13
BustedS13's Avatar
it updates on the site every 2-8 minutes. there's probably better software out there with a less fruity name, i'm guessing. i'll look around
Old 06-18-2008, 06:14 PM   #5
NismoS13Chuki
NismoS13Chuki's Avatar
NismoS13Chuki is on the path to ruinNismoS13Chuki is on the path to ruin
so do you need to activate the phone for use of boost mobile in order to get this to work
NismoS13Chuki is offline   Reply With Quote
Old 06-18-2008, 06:16 PM   #6
BustedS13
BustedS13's Avatar
oh yeah. you need to activate the phone and keep the minimum minutes on it. apparently boost will wipe the minutes every 90 days if it goes unused. as far as i can tell, the minimum is ten dollars, maybe five? $40 a year isn't bad though. and the phone comes with ten dollars' worth preloaded, so you're good for 90 days out of the box.
Old 06-18-2008, 06:18 PM   #7
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
that is pretty badass if it works.
thanks!
skatanic28 is offline   Reply With Quote
Old 06-18-2008, 06:26 PM   #8
DreamN
DreamN's Avatar
Trader Rating: (54)
Good info. I'm gonna see if my friend still has his old boost mobile phone. Wonder if it'll work. If not I'll just head to target or wherever too see if they have the same one you have.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 06-18-2008, 06:28 PM   #9
berz
berz's Avatar
berz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfection
this is dope for the budjet minded
berz is offline   Reply With Quote
Old 06-18-2008, 07:15 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Bury the bitch behind the cluster...
CLICK HERE!!!
Old 06-18-2008, 07:22 PM   #11
shinhed
shinhed's Avatar
When I first read this I thought to myself, "This is all good and stuff, but there's no insurance on your car like you'd have with LoJack". Then I researched LoJack and realized they don't provide insurance either.
This is an epic idea.
shinhed is offline   Reply With Quote
Old 06-18-2008, 07:32 PM   #12
JDM_eightSIX
JDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to all
Wire the power cord for the phone to a power supply with a Toggle switch so the phone isn't constantly charging (Cant be good for battery) and you can keep it hidden somewhere with hard accessibility yet still be able to charge it secretly. Only problem is if you can't add minutes online and have to use the phone to add them.
Just a idea...
JDM_eightSIX is offline   Reply With Quote
Old 06-18-2008, 07:36 PM   #13
allntrlundrgrnd
allntrlundrgrnd's Avatar
thats a pretty sick lookin phone for 40 bucks. awesome idea too
Kouki for sale!!
Old 06-18-2008, 07:53 PM   #14
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
dude bump for best lojack idea ever
i might try this out
wow-thats-a-cool-car is offline   Reply With Quote
Old 06-18-2008, 08:11 PM   #15
SimpleSexy180
SimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfectionSimpleSexy180 is close to perfection
so down.
i already have a spot planned out so i can just take it out at night to charge it.
(i have a garage) then slap it in the car again when i go out somewhere besides home or work.
SimpleSexy180 is offline   Reply With Quote
Old 06-18-2008, 08:16 PM   #16
HyperTek
i nominate the name "Blowjack" lol
i been planin this myself... also good to see where your girl is going *keep track* so i hear lmao
Keep it Classy
Old 06-18-2008, 08:17 PM   #17
allntrlundrgrnd
Originally Posted by SimpleSexy180 View Post
so down.
uhh doesnt that defeat the purpose of having something in the car to track it with?
like busted said just rig a charger up so it can be in there at all times and not risk settin it all up to have it stolen while your gps is chargin. that would suck.
Kouki for sale!!
Old 06-18-2008, 08:34 PM   #18
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Trust issues eh?
This does sound like a good idea.
Might have to try this out on the shell...(since bro is broke as fuck and can't afford lojack.)
-Jspec-
Instagram/CrimsonRockett
Old 06-18-2008, 08:40 PM   #19
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
wow, i'm really impressed
how well the phone acquiring GPS signal?
I had a handheld old school Garmin GPS, sometime it can't get good signal strength if I throw it under the dash
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 06-18-2008, 08:46 PM   #20
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
this is awesome. and you dont have to run all the bitch ass wires that you need to run on a low jack and an alarm. great for us worried about our cars weight
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 06-18-2008, 08:49 PM   #21
SimpleSexy180
i have a garage to park at night... and i work as merchandiser that goes store to store...so i can see my car every minute if i wanted.
the honda-tech thread has some "review"
Old 06-18-2008, 09:12 PM   #22
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
This is awesome, but since its on a honda forum and several others everyones going to know about it..id take the phone apart so it doesnt look like a phone so people wont know what it is. But i wont be able to call the bastard that steals my car : ( HAHA .....KNOCK ON WOOD!!
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 06-18-2008, 09:21 PM   #23
projectRDM
projectRDM's Avatar
Just a idea...
Phone chargers pull no more current than an alarm LED, it'd need to be left untouched for several weeks before draining the battery enough to lose power.
FORMERLY R240NA
Old 06-18-2008, 09:32 PM   #24
iluvpandas4
iluvpandas4's Avatar
iluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfection
Send a message via AIM to iluvpandas4
wow just took my sister's old boost, now i just need to pick myself up a couple of things.
'92 240sx Coupe
iluvpandas4 is offline   Reply With Quote
Old 06-18-2008, 10:06 PM   #25
BustedS13
BustedS13's Avatar
Just a idea...
just a great idea, because i love switches. i'll wire it to constant power on a toggle switch. NEED MOAR SWITCHES!
edited first post.
i've read this phone gets good gps signal, but i'm going to mount it somewhere close to glass so it'll get the best chance it has at it. also, i think it'd be important to keep it somewhere accessible, in case the phone crashes or something. i'll never take it out of the car, but i'd like to be able to check it out every week or so to make sure it's still operable.
oh, and you can "reboost" on boost mobile's website, so no real need to dig the phone out of its hiding spot to add minutes.
Old 06-18-2008, 10:08 PM   #26
allntrlundrgrnd
or SlowJack
hehe
Kouki for sale!!
Old 06-18-2008, 11:08 PM   #27
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
I can not wait until somebody actually recovers their car due to this. Post up your story it should be pretty swell.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 06-19-2008, 12:26 AM   #28
HyperTek
what could you do? tell the police "my gps says the car is at this address, think you can go check it out if i give it to you? uhh after your donut break of course if you dont mind =p "
Or go yourself hoping to find it? seems most of the horror stories cars are recovered in outsiding cities.
Keep it Classy
Old 06-19-2008, 12:50 AM   #29
SRpetey
SRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really nice
could it be possible to wire the phone charger to an illumination wire? That way it only charges when you turn the light switch over and not all the time.
SRpetey is offline   Reply With Quote
Old 06-19-2008, 01:06 AM   #30
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
question....does the phone need to be on in order to track it?... or just have some battery power. cuz that would affect how you'd need to charge it.
most phones will only stay in standby for like 3 days....but if you could leave it turned off then you'd be set
96Turbo is offline   Reply With Quote
