Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 03-26-2011, 03:49 PM   #1
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
s13 Stuck at work! Lunch break and bad idle!
MISPOSTED SORRY!
So i leave work for my lunch break head over to mcD's to get some grub, and on the way i notice im running real rich.. i can smell the fuel and my wideband is reading 11-12 with very little load. Getting some loud backfires while decelerating. Idle is terrible struggles to keep running idle bounces from 100-1100 and stalls outs completely if i dont tap the gas. i have been running fine for the last month or so with a steady idle. havnt made any changes, what could have gone? im thinking random vac/boost leak which i can test when im off work. also i know the CTS going bad can cause similar issues. any extra thoughts would be appreciated since im at work and would like to make it home in one piece.
Mods: Sr20det with t28, stock maf injectors/ecu. walbro pump. fmic and freddy intake.
Last edited by ultimateirving; 03-26-2011 at 04:10 PM.. Reason: wrong forum sorry guys , ill repost in engine tech like i thought it was supposed to be
ultimateirving is offline   Reply With Quote
