Old 12-29-2011, 07:23 PM   #1
jdizzy204
jdizzy204's Avatar
jdizzy204 will become famous soon enoughjdizzy204 will become famous soon enoughjdizzy204 will become famous soon enough
3 piece wheel question
I have a pair of 18 inch 3 piece wheels. Is it possible to remove the face and put it into a 17 inch lip and barrel hence making a pair of 17 inch 3piece wheels?
The face is 41cm and 36 holes
Tokyo, JP
jdizzy204 is offline   Reply With Quote
Old 12-29-2011, 07:30 PM   #2
dagger
dagger is an unknown quantity at this point
the nismo ones in your tumblr?
Ive seen people use bigger lips on bbs rs n stuff, I think it depends on how big the face is
dagger
dagger is offline   Reply With Quote
Old 12-29-2011, 07:36 PM   #3
icedsole
icedsole's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
pretty sure you can only barrel up. like from 17-18
but im probably wrong
@pwrmves14
Old 12-29-2011, 07:40 PM   #4
jdizzy204
jdizzy204's Avatar
Yea, Nismo never made 17" LM-GT1s and I'm all about the 17/18 stagger. I just figured I'd see if anyone knew.
The face is less than 17" so there might be hope. I just emailed a few companies that make custom lips and barrels about it too.
Tokyo, JP
Old 01-03-2012, 12:55 AM   #5
alexisthemovie
alexisthemovie's Avatar
alexisthemovie is an unknown quantity at this point
Send a message via AIM to alexisthemovie
What wheels are they?
My Build
http://wheelflip.com
alexisthemovie is offline   Reply With Quote
Old 01-03-2012, 01:20 AM   #6
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
You can only upsize. I've never heard of downsizing a face. You'd have to shave and re-drill mounting holes. It doesn't work that way.
Old 01-19-2012, 02:53 AM   #7
jdizzy204
jdizzy204's Avatar
They are Nismo LMGT1 wheels. The wheels have a stepped lip. Also the face sits on top of the outer lip and barrel (not sandwich mounted like BBS RS)
This leads me to believe that the faces can fit in 17 inch barrel/lip as long as its not stepped.
So where can I order custom 17" 36 hole reverse lips/barrels?
Tokyo, JP
Old 01-19-2012, 06:41 AM   #8
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
May want to measure before you order unncessary parts. Just a friendly tip.
Old 01-19-2012, 06:45 AM   #9
OBEEWON
OBEEWON's Avatar
If you went to a reverse lip you might be able to go down in size. But only if the face is small enough.
Old 01-19-2012, 06:58 AM   #10
jdizzy204
jdizzy204's Avatar
the face is 41 cm(total diam.) and 17 inches=43.18 cm it should be possible. the center of the bolt holes are 1cm away from the edge of the face so it could work if i found someone to sell reverse lips with an air valve in the appropriate place.
Tokyo, JP
Old 01-19-2012, 07:16 AM   #11
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Hit up VRwheels. I know they do a lot of custom stuff. They're your best bet.
Old 01-24-2012, 05:01 AM   #12
indytrucks
indytrucks's Avatar
indytrucks is an unknown quantity at this point
You sure they never made 17" LMGT1's?
17x9 FYI. Only 2 piece though. Never mind, I guess these are LMGT2?
indytrucks is offline   Reply With Quote
Old 01-24-2012, 06:07 AM   #13
jdizzy204
jdizzy204's Avatar
Yup those are lmgt2s
Tokyo, JP
