Old 05-29-2013, 09:08 PM   #1
justin_bfn
justin_bfn's Avatar
justin_bfn is an unknown quantity at this point
rb20det running issues
Okay so this has been a problem for awhile now and ive tried a few things and can't figure it out. Here's what happens. First off it idles way high when its warming up. Recently got a new iac it helped but didn't solve the issue. After its warm it idles lower, but still high. Also when its warm whenever i come to a stop it wants to die, and i save it by giving it gas then it blows a little bit of black smoke out then idles back up. I thought it was my tps so i put a new one on it and it still has high volts when going to adjust it. So basically what i've got it boiled down to is its over loading on fuel and i can't figure out why. Would it be faulty wiring somewhere for the tps? or cas timing is off? or boost leak somewhere? Iac gasket? Fuel filter? Fpr is new and set right, plugs are gapped at .8 and fine. And like i said before the iac is new and cleaned. If someone could suggest something or help that would be greatly appreciated.
Thanks
justin_bfn is offline   Reply With Quote
Old 05-30-2013, 12:19 AM   #2
S12 Drifter
S12 Drifter's Avatar
S12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymore
what is high? 5,000rpms? it might be your air regulator or tps.
Originally Posted by S13slida View Post
Your wife has bigger balls then you.
S12 Drifter is offline   Reply With Quote
Old 05-30-2013, 12:20 AM   #3
justin_bfn
justin_bfn's Avatar
2700. But my tach could be off as well.
Old 05-30-2013, 12:23 AM   #4
S12 Drifter
from ear does it sound like it's idling high? like waaaaaaaaaaah
or does it sound nice and calm?
Old 05-30-2013, 12:25 AM   #5
justin_bfn
justin_bfn's Avatar
Sounds normal to me. Just sounds like a rb20 that idles high lol.
Old 05-30-2013, 12:26 AM   #6
S12 Drifter
look on google and try messing with your iacv screw setting.
Old 05-30-2013, 12:27 AM   #7
justin_bfn
justin_bfn's Avatar
It's all the way shut. Could a bad air regulator cause high voltage on the tps?
Old 05-30-2013, 12:42 AM   #8
S12 Drifter
get come air flow cleaner and try cleaning the air flow. might be that. try to reset the ECU.
also another little trick is get some carb cleaner and spray it all over the intake manifold the rpms might drop and if they do or get higher you have a vacuum leak.
Old 05-30-2013, 12:43 AM   #9
S12 Drifter
also try cleaning your iacv they get junky
Old 05-30-2013, 12:45 AM   #10
justin_bfn
justin_bfn's Avatar
I have done all of that lol. Except the intake mani thing. I'm leaning with the regulator. I never even thought of that. It doesn't like cold starting either so it all makes sense.
Old 05-30-2013, 01:11 AM   #11
S12 Drifter
For the most part all nissan air regulators are the same. Just the housing that changes.
Sent from my SPH-M920 using Tapatalk 2
240sx, rb20, rb20det, s13, s13 coupe
