For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: Apr 2008
s14 SR MISC STUFF RADS, LONGBLOCK, MISC SHOP CLEAN UP
Hello i went ls last year and have a bunch of sr stuff left behind. All of it needs to go. All prices are obo and do not include shipping unless specified. If you do not see a price then make offer. Everything is located in WPB, Fl. My # is 561-308-6083 Name is Bill 9am-12pm please. Or pm. I have tons of stuff i will be updating this thread in my spare time.
s14sr oil filter tree housing 25 s14 sr coolant temp sensors 15 shipped s14sr thermostat housings 15 hoses under intake mani s14sr injector to manifold grommets 2 sets 10 each set s14sr injector spacers between rail and intake manifold 2 sets 10 per set. s14 sr a/c compressor brackets with tensioner pulley and hardware. 20 S14 sr vtc solenoid and vtc cam sprocket as a pair 75 s14 sr alternator great condition 60 s14 sr water neck upper coolant outlet/neck SOLD Jvtr huge aluminum s14 sr rad Like new used two events or 3 before the ls swap. 125 pickup preferred. SOLD stock s14 sr rad no leaks good condition SOLD sr down pipe one ugly weld by trans hanger.This is a long downpipe ans eliminates the need for a test pipe. 45 SOLD s14 blower motor resistor if you ac doesnt blow on all speeds u need this. Almost new from dealer. cost $40 how about 15 rear seats some fading at the top s14 kouki 10 s14 sr longblock complete from head to oil pan. less than 70k miles! No valve cover or vtc equip. Was a great engine until i blew the factory headgasket, still ran great no water in the oil or anything. Just a small leak of compression into the cooling system. I removed it and went ls1 and have never looked back. $300 pickup preferred. SOLD S14 sr fuel rail, exhaust mani heat shield, and knock sensor I have 2 knock sensors make offer. 2 S14 sr iacv Idle air Control Valves 40 each sr20 adjustable cam gears removed from s13 sr. Unknown brand Sr trans pivot forks, s13 sr speed sensors, trans pivot balls, misc sensors, mount bolts and nuts, throwout bearing retainers. Make offer. ka distributor with wires known good condition. I think s13 but it is external coil. check the plug to verify. 25 S14 a/c climate control head. A/c controls Known Good working cond 30 s14 sr rocker arms 60 for all 8 s14 sr rocker arm shims 10 for whats shown s14sr t28 compressor outlet 25 INLET SOLD s14 sr flywheel bolts good cond 10 SOLD s14 sr pistons and rods pistons in great shape 1 rod bearing was spun. 3 good. 25 SOLD s14 seat belts i have many of these but this one was in my way so i took a pic 25? Pioneer cd/mp3 deal out of my race car was in good working cond when removed about 6 months ago. should have the remote some where. Pre wired for s14 50? s14 black ash tray 15 s14 sr upper oil pan good cond make offer pair (2) 225-45-17 hankook ventus tire 75% tread 65 SOLD s14 sr a/c bracket, alt bracket, p.s pump bracket make offer s14 open diffs 40 s14 welded diffs 90 s13 welded diffs 75 s13-14 axles 25 each lots Last edited by BILLFISHER21; 11-12-2011 at 10:45 AM.. |
