Old 05-23-2005, 09:41 PM   #1
loveless
loveless's Avatar
loveless is an unknown quantity at this point
Send a message via AIM to loveless Send a message via MSN to loveless
s15 turbo (91F00) better or GT28R?
both are around 750 to 800 brand new
just wondering which one is better?
... too general? I want to run 15psi off of it, bottom mount, no internal work, no head gasket, goal is around 300rwhp. Car will be daily driven so I guess quick spool/making more power at low spool is a plus
loveless is offline   Reply With Quote
Old 05-23-2005, 11:33 PM   #2
loveless
loveless's Avatar
no comments?
Old 05-24-2005, 12:02 AM   #3
RSP13-Sideways
RSP13-Sideways's Avatar
RSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her self
Send a message via AIM to RSP13-Sideways
S15 cause it's OEM Nissan.....and it's done right.
- Jay
WTB: Nothing at the moment. LEWL
WTS: Everything sold, thanks folks!
RSP13-Sideways is offline   Reply With Quote
Old 05-24-2005, 12:33 AM   #4
loveless
loveless's Avatar
it's not realyl oem though... it's made by garrett as well, both are identical visually and price
Old 05-24-2005, 01:06 AM   #5
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
You might want to double check this since I'm not 100% sure but I remember someone saying the S15 turbo has the cast in divider wall between the wastegate and turbine discharge while the GT28R doesn't. That would be the only reason I'd look for a S15 turbo over a regular GT28R, if that's true.
atom is offline   Reply With Quote
Old 05-24-2005, 01:25 AM   #6
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
research more before asking for opinion based decisions. especially when it comes to turbo choice. still even tho both are made by Garrett. One is made to nissan specs while the other is made to manufacturer specs. Similar design doesn't mean they are the same. Most people in the past on this forum have gone to the s15 turbo then later on went up to the GT28/rs and beyond. 300 flywheel HP or 300whp that is another determining factor also.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 05-24-2005, 02:05 AM   #7
loveless
loveless's Avatar
this is a s15 turbo, what advantage does the divider have? it doesn't look like it's completely sealed
does it have to work with sometrhing like this?
Old 05-24-2005, 02:58 AM   #8
atom
It's actually one or the other. If you have an O2 pipe like the one you linked to or the greddy O2 it won't work on the S15 turbo without modification because the cast-in divider will interfere with the divider on the O2 pipe. You're right when you say the S15 divider isn't completely sealed, it looks to me it's only meant to seperate airflow directly at the mouth of the turbine and wastegate discharge. That's where the turbulence would have the biggest effect anyways.
Cliff notes:
If you have or want to upgrade to divided O2 pipe (like greddy) = get turbo without built in divider.
If you have or want O2 pipe that isn't divided (like megan racing or stock) = get turbo with built in divider.
Old 05-24-2005, 05:16 PM   #9
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
From what I have seen 300whp will not come from 15psi. You will need cams/intake manifold and about 18-20 psi to reach those numbers. I would honestly step up to a gt28rs, you are going to be pushing that turbo awfully hard
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 05-25-2005, 01:35 AM   #10
93 240sxfastback
93 240sxfastback is an unknown quantity at this point
If you're getting into gt28rs price range I'd rather have a gt2871r.
93 240sxfastback is offline   Reply With Quote
