z32 240sx brake master cylinder info
ok guys not sure if its been covered? I'm assuming it has not sense i have not found anything about this anyplace, if your looking to swap in the 300zx z32 brake master cylinder you dont need to buy the TF one for $250-$220 and you dont need to cut out your old master's 3rd fitting and press it in the new master, if you order from CENTRIC PARTS 1990-1991 nissan 300zx turbo master cylinder part #130.42603 it has the 3rd fitting installed its 17/16 in size and also comes with the allen fitting to block the 3rd fitting's hole. I can vouch as i just got one, i had seen pics online of the CENTRIC master and all the pics had the 3rd hole open and with the fitting installed so i ordered one, its $60-80 bucks depending on where you get it. figured i share the info,
---Fellow 240sx owner George F. aka.. DAGeorgie
