Old 05-24-2011, 11:12 AM   #1
NINJASPY
NINJASPY is on a distinguished road
Fastrax DIY Alignment Tool
solddddddd
NINJASPY is offline   Reply With Quote
Old 05-24-2011, 11:30 AM   #2
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Are there instructions for its use?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 05-24-2011, 11:33 AM   #3
NINJASPY
yes I have the instructions, or look on you tube.
Old 05-24-2011, 12:47 PM   #4
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
great tool to have, we use one at the track all the time... free bump!
Coolwhip is offline   Reply With Quote
Old 05-24-2011, 01:30 PM   #5
240sxvaj
Trader Rating: (38)
240sxvaj is an unknown quantity at this point
Feedback Score: 38 reviews
I wanna see if this thing is accurate.......
240sxvaj is offline   Reply With Quote
Old 05-24-2011, 01:49 PM   #6
NINJASPY
its accurate if you use the tool correctly, mount it on the wheel the same way on each wheel, AND have a flat ground which to zero in the gauge. If you are looking to get perfect alignment to the .1 degree, then you should go to a computerized alignment shop. There is a reason why hunter machines cost 20+k.
If you are at the track and need to adjust alignment and have them equal on both sides, then this tool will work.
IE, its a good way to add or take out camber/toe and have them equalized on both sides.
Even alignment shops get it wrong. Most (99%+) do alignment with you outside of the car, 150-200lbs sitting in the drivers seat will mess up the alignment, no matter how you look at it.
You are welcome to come test it out if you want to see how accurate it is. Or just look on youtube.
Old 05-24-2011, 01:51 PM   #7
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
how much for it shipped to 87144?
NMs14.5kouki is offline   Reply With Quote
Old 05-24-2011, 02:12 PM   #8
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
I own and use this exact same tool and it works well! Best results if your on a FLAT and EQUAL surface.
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline   Reply With Quote
Old 05-24-2011, 02:31 PM   #9
!Zar!
!Zar!'s Avatar
Mmm, nice price and nice to have...
Old 05-24-2011, 02:36 PM   #10
GSXRJJordan
GSXRJJordan's Avatar
I'll take it. Sending you PM now.
