Old 02-11-2009, 10:50 PM   #31
fckillerbee
fckillerbee's Avatar
Originally Posted by articdragon192 View Post
Just wondering what psi everyone runs for drifting at the track. Figured this might help get newbies started on some sort of car set up and possible have some other intermediate drivers try something new and learn something from it.
Please post up tire size, PSI used, and around how much wheel HP you're running. If you're on a stock motor, just say that. I'll start off
Front:
255/35-18
32 psi cold
Rear:
245/40-17
45 psi cold
Around 195 whp.
Might play with the psi a bit more though.
300zx felt like a FC. Well, at least the twin turbo one, so 245 or bigger works well. 40 psi in the rear, 35 in the front.
Old 02-11-2009, 10:51 PM   #32
l20bdime
l20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of light
KA-T estimated under than 300hp.
225/35r18 federal SS front: 30psi
245/40r18 federal SS rear: 30psi
I run nitrogen in my tires which keeps the pressure from going up when the tires get hot. so its 30psi hot or cold. 18 inch federals chunk but since ive been doing this they've been really good.
when i had stock KA i ran 225/45r17 federals at 50+psi. that way you can actually make smoke with a KA.
l20bdime is offline   Reply With Quote
Old 02-11-2009, 10:55 PM   #33
fckillerbee
Yeah I don't make smoke...gonna try raising to 60psi...see what happens on the next "dry" drift event. How do you get nitrogen into your tires? have it hooked up to a tank?
Old 02-11-2009, 11:16 PM   #34
techtrix
techtrix's Avatar
techtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfectiontechtrix is close to perfection
yeah just rent a nitrogen tank from a welding supply store.
Michael Essa GSR Autosport
techtrix is offline   Reply With Quote
Old 02-12-2009, 08:40 AM   #35
l20bdime
i work at a nissan dealer and we have a machine for the GTR's where you hook up hoses and it drains out the old air and adds nitrogen, then repeats to make sure its pure.
Old 02-12-2009, 10:30 AM   #36
fckillerbee
wow...that's pretty amazing.
Old 03-30-2014, 10:48 AM   #37
coty_garcia
coty_garcia is an unknown quantity at this point
Bump to get this thread going again lol
coty_garcia is offline   Reply With Quote
Old 03-30-2014, 11:37 AM   #38
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
40psi on any and all tires on my car. Hot or cold, when I check, if its not 40, I will set it to 40psi.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 03-30-2014, 02:05 PM   #39
xoxide
xoxide's Avatar
25psi front
19psi rear
Old 04-01-2014, 04:16 AM   #40
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
I totally agree with citytire and tire pressure is very dependent on many factors. Granted, there is somewhat of a starting point, but it really depends on what youa re after. I like to run a lower pressure so the tires grip more and i can drift faster.
Rule of thumb is, if you want more grip lower the pressure and less grip you increase the pressure.
It definately pays to have a good "calibrated" if possible guage. Some of the crap you can buy at autozone etc could potentially be off from what it's reading.
If your serious about drifting, tire pressure is a BIG deal. If not and just have fun, just play around with it and see how you like the feel of the car and how it reacts under different pressures.
Luvs2slide is offline   Reply With Quote
Old 04-01-2014, 04:19 AM   #41
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
The Bee-R B5 wheels actually have dual valve stems for this purpose. I'm surprised alot of other wheel manufacturers havn't caught on.
You basically get a more balanced tire as well in addition to lower tire temps.
Old 04-01-2014, 11:39 AM   #42
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
Stock S14 SR
F: 225/35/18 Federal SS595 40 psi cold
R: 225/40/18 Delinte D7 45 psi cold
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 04-11-2014, 12:18 AM   #43
NERPtech
NERPtech is an unknown quantity at this point
Measuring cold tire pressure isn't going to do you any good. Most tires aren't going to heat up the same as the next brand. I have started with 40 cold in the rear after 1 lap was up to 68 ish.
I have found at 150whp that
Front 30psi hot
Rears 36-40 psi hot. Depending on the wheel and tire I have on. Ranging from 215/45 - 235/40 ish
NERPtech is offline   Reply With Quote
