Old 02-12-2016, 04:47 PM   #1
DewMan000
DewMan000 is an unknown quantity at this point
Speedo not working due to tranny swap help please
So I just purchased my first 240. It's a 97 s14 with a ka24de-t and a swapped c009 350z tranny and because of the swap my Speedo won't work. How do I fix it?
DewMan000 is offline   Reply With Quote
Old 02-12-2016, 06:03 PM   #2
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
No speed sensor on Z trannys
Old 02-12-2016, 06:04 PM   #3
rawgarage
Trader Rating: (75)
If you ran an S15 diff you could get a speed reading off that
Old 02-12-2016, 06:13 PM   #4
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
I have a autometer GPS. Haven't installed it yet. But could be a solution.
RickS14 is offline   Reply With Quote
Old 02-12-2016, 07:25 PM   #5
DewMan000
Anyway to hook up a sensor without switching out my diff?
Old 02-12-2016, 10:09 PM   #6
RickS14
RickS14's Avatar
Speedo not working due to tyranny swap help please
This is what I'm talking about some sc guys running the cd Trans use this.
Old 02-13-2016, 03:43 PM   #7
DewMan000
Thanks I'm gonna put one in save myself the trouble of changing out the diff
Old 02-13-2016, 08:23 PM   #8
RickS14
RickS14's Avatar
No problem trying to help.
Old 02-15-2016, 09:22 PM   #9
collegekid
collegekid's Avatar
collegekid has made poor choicescollegekid has made poor choicescollegekid has made poor choicescollegekid has made poor choicescollegekid has made poor choicescollegekid has made poor choicescollegekid has made poor choicescollegekid has made poor choices
I forget which company (maybe Dakota digital) but there was a unit that had you install something on your driveshaft and it measured that to give you a speedometer signal.
A google search showed spectec engineering has some sensors.
Honestly I would call the driveshaft shop, they could recommend you to someone. Im sure there's a way you can get a simple digital signal setup. I didn't know about the cd trans not having a vss in them.
collegekid is offline   Reply With Quote
Old 02-17-2016, 10:35 AM   #10
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 is an unknown quantity at this point
Feedback Score: 18 reviews
The speedo sensors are in the rear diff on the 350Z, similar to the S15 setup. The ABS signal is used for the speedo in the Z33 (2 sensors) and the S15 (1 sensor). You need an ABS diff from an S14/S15, or J30 or I think Z32. These have an ABS sensor in the front of the diff, the Dakota digital box can then be used to "convert" the ABS signal into the speedo signal.
The GPS sensor is probably a good option if you can't find an ABS diff, but I'd be worried how reliable it is (signal dropping due to trees, tunnels, etc).
LoSt180 is offline   Reply With Quote
Old 02-26-2016, 09:18 PM   #11
DewMan000
Not too worried about it dropping out I just need a Speedo that works so I can get it stickered they're kinda douches about things like that here in New Hampshire
