Old 04-10-2013, 01:50 PM   #1
paintkilz
paintkilz is an unknown quantity at this point
able to reuse harness wiring pins? or where to buy?
i was curious if anyone has every depinned any plug and was able to salvage the pin the wire is crimped to itself?
im shortening and hiding my fuse box in the dash and id rather repin it than solder and seal all the wires..
ive tried googling but i dont think im using the right terms to get good results..but im not having any luck at finding new pins to use..
thanks for your help guys
paintkilz is offline   Reply With Quote
Old 04-10-2013, 07:00 PM   #2
paintkilz
no reply and all these views?
ill just do the standard zilvia approach and cut wiring then splice it with Harbor Freight electrical tape...
Old 04-10-2013, 07:14 PM   #3
Sileighty_85
Sileighty_85's Avatar
no you cant, other than cutting and soldering.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-10-2013, 08:58 PM   #4
The Dude
The Dude's Avatar
The Dude is an unknown quantity at this point
Auto-Vehicle Parts Co.
Download catalog and/or call these guys. They probably have what you're looking for as far as pins go.
That said, I would just cut/solder/heat shrink wrap all of the wires.
The Dude is offline   Reply With Quote
Old 04-11-2013, 10:35 AM   #5
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Yeah i havent seen anywhere that sells just pins, especially since there is such a variety.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
