For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
02-23-2015, 10:19 PM | #1 |
Trader Rating: (106)
Feedback Score: 106 reviews
Random S13 5-speed parts
S13 DOHC 5-speed lower harness
This is a good condition KA dualcam lower harness. All connectors are there and the harness is 100% functional. The only issues with the harness is the starter signal wire connector has been replaced with a regular spade connector, and the rubber boot for the main battery wire to the starter is missing. Neither of these are any sort of significant issues, the regular spade connector plugs into the stock start signal connector just fine. This harness is NOT NECESSARY for a 5-speed swap. It will NOT plug into an auto trans car. Original 5-speed cars ONLY. Also, the SOHC KA lower harness is different as it has the power steering pressure switch connector on it and for CA cars it also has the EGR temp sensor connector on it. If you don't care about either of those functions it will work just fine on a SOHC 5-speed car. $40 KA M/T starter bolts This is a pair of mis-matched S13 manual trans starter bolts. The heads of the bolts are different size, but the thread length and pitch are the same and correct for a manual trans KA. $5 S13/14 clutch/brake pedal pins These are the pins that attach the clutch and brake pushrods to the pedals. These are all from the brake pedal originally, but work for either pedal. All 4 pins have the clips with them. $5 each One pin sold, 3 left Last edited by racepar1; 03-26-2015 at 10:05 PM.. |
