Old 02-02-2012, 07:19 PM   #1
soryu
soryu's Avatar
soryu is an unknown quantity at this point
KA rtv or cork rubber gasket?
was thinking what are you guys using.?
for the oil pan gasket are you using the rtv sealant fsm says to use it or did you just drop in a gasket from your local auto shop?
i used the rtv sealant and it's leaking worse than before.
gonna try again but just wanted to check what everyone else is using.
soryu is offline   Reply With Quote
Old 02-02-2012, 07:30 PM   #2
DRIFTERS14
DRIFTERS14's Avatar
DRIFTERS14 is an unknown quantity at this point
rtv is the best
( make sure u allow it to dry before u put oil back in)
i used toyota FIPG ( never had any issue)
part number 00295-00103
DRIFTERS14 is offline   Reply With Quote
Old 02-02-2012, 07:32 PM   #3
slider2828
slider2828's Avatar
Just use permatex black.... Clean surfaces with carb cleaning. Dry for 2 minutes, hand tight for about 20 minutes, then tightened to tork spec....
Turn and Burn!
Old 02-02-2012, 07:45 PM   #4
Kingtal0n
Kingtal0n's Avatar
razor blade -> brake kleen -> permatex grey.
everybody has their own way
Old 02-02-2012, 08:42 PM   #5
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
rtv all the way. make sure you clean and dry both mating surfaces and make sure oil pan is not warped. lay about 1/16th of an inch thick on the whole width of the oil pan. let it dry for about 5 minutes and install. make sure you don`t hit anything that would wipe the rtv off the pan.
rcdad123 is offline   Reply With Quote
Old 02-02-2012, 09:01 PM   #6
boms
boms's Avatar
boms is an unknown quantity at this point
Honda bond
boms is offline   Reply With Quote
