#751 |
![]() Join Date: Jun 2008
I will probly have a dyno sheet up this week. 9 psi low boost just to see where its at until i get extra money for a high boost tune.im also on stock cams. hopeing for 260-270whp on the dyno jet.
#752 | |
#753 |
![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I just want to start off by saying thank you zilvia. You guys helped me through some hard times and I finally got to show what my car was made of before I left. I did not get what I wanted but I am satisfied. 356HP 306 torque on a dynojet.
MODS: gt2871r 64 tomie 740 injectors the front mount that came with the heavythrottle package. Think the lowest greddy one. Freddy intake manifold 300zx maf tomie elbow 3 in exaust w/ apexi n1 S3 cams apexi 1.1 headgasket jwt tuned ecu fine tuned with afc neo bunch of other little goodies Boosted at 18psi and air fuel ratios were at 11.5. Wanted to go a little safe.
Thats what I said ![]() Last edited by moses; 02-07-2009 at 04:51 AM.. |
#754 |
Haha, I say I want to stay safe and look what happens
That is my #1 spark plug. NEVER TAKE YOUR 240SX ANYWHERE IN ARKANSAS FOR ANYTHING. I swear I hate this place. I posted it in tech talk if you have any comments.
Thats what I said ![]() |
#757 | |
take. ![]() Last edited by S13 curtis; 02-09-2009 at 06:36 PM.. |
#758 |
![]() Join Date: Oct 2004
Hey everyone just wanted to post my numbers with a PFC DJetro on a DynoJet.
GT2871R .86AR non-GT frame 264 HKS Step1 Stock IM/EM Greddy Elbox Catco Cat Blitz Downpipe Blitz Exhaust with Silencer Blitz LM Intercooler Apexi 1.1 DW 600cc Greddy Profec E01 - @ 14PSI up to 25MPH and 16psi 25+MPH What you guys think? 0 smoothing....
#759 | |
![]() Join Date: Dec 2006
I might go for that when i want more power :P
![]() 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#760 |
I had Steve dyno my car on the Dyno Dynamics and i only got 264whp. I almost cried lol i held it in though hahaha. My JWT tune runs rich though...wasnt even in the 11's for WOT A/F ratio.
my main power set up: GT2871r .64 264/274 cams Megan Ex. Mani and some other goodies McKinneys is helping work through this though. my FPR was at 40PSI but was running so rich i could even drive at one point...oh well the time will come where i will hit over 300whp on the DD. |
#762 |
damn dude thats impressive. i have the .64 so i wont make that but i'll take 350whp hehe.
This shit is getting crazy though...it might be the injectors so we're sending them to LA to get tested...also, the conditin is getting worse...i'm taking it off the streets today for however long it takes to fix...it's so damn depressing...i've been drinking my self to sleep everynight... |
#763 | |
I made 363whp on Stock cams and Intake Mani @ 21psi
#764 |
Looking for opinions, ideas, suggestions
I have s14 sr20det being fully built Wiseco Pistons Eagle Rods Arp Head Studs Arp Main studs Balanced crank Apexi Head Gasket BC Springs/TI retainers HKS s2 272s (intake/exhaust) Greddy intake manifold AEM EMS Sard FPR Nismo 740cc GT2871R .64 Was thinking bout running E85 but then would have to upgrade injectors, so i guess what im asking is how much power should i make on the 2871r pump gas (93) and now that motor is built to withstand much more power then 2871r will provide What other turbo options do i have |
#765 | |
![]() Join Date: Jan 2008
gt2871r .64, 264 cams, greddy intake, Mr exhust and o2 740cc z32maf
My Twin Scroll Gt30r Sr22det Build |
#766 | |
Basically you built a GT3071R with a 28R wheel. In most cases in my experience the reverse theory works best on SR's. Smaller housing huge turbine wheel, matching (in mass) front wheel, moderate sized intake housing. Interested to see the results though ![]() I think you guys should be very careful when evaluating comparing dynos: 1. Dynos work off a lot of correciton values, if one of these is off or the dyno operator is not fully versed the dyno will ready WAY HIGH or WAY LOW a. barometric pressure b. air temp input c. RPM inputs d. Dyno Type and applied load or mass of roller These will all make huge differences to the peak output number that you end up hitting. Most of the 2871R cars I have tuned have been very hodge podge setups. Meaning the injectors were not correct make/model, injectors were leaking, ECU was damaged or not working correctly, boost was dropping off and not holding at all due to faulty or improperly installed boost controller. I believe the 2871R cars usually produce lower outputs (Compared to all other tunes I have done) because the bottom mount 2871R crowd is one that is looking for the most cost effective options for the highest number. This means that many other solutions like fuel or other installation costs were also kept low for cost effective output. There needs to be careful decision making as a consumer who is really out for the best and most fulfilling setup in making the right decisions on cost and what demands and standards you keep your installers to. http://www.youtube.com/watch?v=7i3JX18cGPs One of the better 2871R cars I tuned was Jordan's - Jordan is extremely thorough and this shown through in the quality of his. 15-16 psi 100% stock motor with just a 2871R .64 with FMIC and PFC - we later found after Jordan left that we had the load set high on the dyno - so the car was actually reading about 12% or so less than it should have been. Here are some things to assure you get the most of your 2871R Turbo, no matter what tuner you go to. 1. Buy the right supporting modifications Most of the customers that I have that build high output SR20s build them with good supporting mods and have no leaks, no issues at all and all the high budget items have been purchased in the right places. 2. Make sure the shop that does/did your initial motor swap got you a high quality engine and did a thorough installation - including A. SETTING THE CAS INTO THE HEAD PROPERLY - TESTING THE CAS!!!!! I can't tell you how many cars I have had in with damaged CAS or improperly punched CAS so the base timing target cannot be properly matched or hit. This is essential to properly tuning SRs. I have had cars from the highest and most well know shops (you would be blown away) with bad CAS, that were dynoed on dynojets wtih Baro correction on just to get them the numbers they wanted and out the door. 3. Make sure your boost controller and wastegate setup are effective solutions and hold boost stready all the way through the rev range. I also highly suggest all of you start investing in the ATP external WG integrated housing. I usually don't support shops that I don't have a great current working relationship but I think this is the solution to all the 2871R woes for perfect boost holding and performance of the wg. 4. Again make sure your ignition system is in good condition, your grounds are done correctly and your ECU is up to the task. 5. Invest in the right EMS. If you are serious about reliability and consistency seriously look into investing into a Haltech EMS. AEM was not properly designed to work with the Nissan CAS and trigger wheel right out of the box and the steady state tuneability is not even close to efficiency as the HALTECH. Power FC is also a good option but I suggest going with Tomei Rytech - this unit is actually also made by the Haltech company (yep!) and is another great plug and play map based unit. Map based means tuning for ignition, direct X timing for Y boost - on pressure, this means more power and more reliability for a turbo car that is setup for performance. In the end the quality of the work you put into your own personal installs and the quality you demand from the shops that are frankly reaming a lot of you guys is what will make the dyno session and final output the best - give the tuner has experience and is familiar with your EMS. Thanks and PM me for smaller qs ill try to get back if I have time
Like Me on FaceBook ![]() |
#767 | |
#769 |
the 30r comp housing had a big difference for my friend that tunes my car.
he has a 2871r.64 with a t4 gt30r comp housing. 300whp @ 10 pounds i know its a different motor but he was on stock cams also. heres the link. www.ka-t.org :: View topic - 296rwhp on 9.5psi (vid inside) |
#770 |
Got new numbers after Steve work his magic. Steve is hands down the best, any cars tuned, Ima send it his way.... I gotta say magic, cause the gains are disgustingly sick. A lt better than I thought..... Myfirst dyno was on the dynojet was on 93 with HKS264 Step1's and now Same setup same boostlevel at 16.5 (same as before) but with steve's tune and 91 gas.....
Its neck snapping fast geezus.... 200lbs of tq at 4000RPM ![]() On a dyno dynamics, oh and still has a full cat with silencer stock IM and EXM.... I think that is enough or me.... Inspiration was Mine's 34 GTR, just focus on response....! Geezus I also just notice 295 Lbs of Torque at 4800 RPM.... Get a neck brace time! ![]()
#772 |
![]() ![]() ![]() Feedback Score: 1 reviews
I had a .86, oil seal went bad. bought .64
Same dyno, maybe a year apart. Tuned for the .86. 300hp is old one, psi spiked at 19ish then dropped to 16-15ish. and this was an ebay manifold. new 323hp is with stock manifold and psi hitting 16 and climbing to 17. aem shows hitting 16 at 3800rpm. Ignore AFR's wideband and dyno were .5 off. At 4kish it was 50hp gain and 70 lb ft. yes i know it could use some tuning, this was just a baseline. Cams are HKS step1 256, yes i know i need something better but 320hp is good for right now. unless someone has some S3's to sell me. |
#773 | |
#775 |
![]() Join Date: Nov 2003
408HP/382TQ Mustang Dyno 56trim .82 T3, log manifold, 38mm external gate, HKS 272 step 2's. Peak to 19psi and end off at 16psi on shitty tune.
Lower than a pornstar's morals. |
#776 | |
bout $1500 in parts $900 for machine work and assembly, did almost everything myself except putting block together didnt want to deal with gapping rings and shit |
#777 | |
im going with 272 cams like you. jus wait till you get a better tune and 24 psi. thats about 430whp on the dynojet if im correct. nice #'s BTW ![]() what were your previous # with the T2 .86 |
#778 |
![]() Join Date: Dec 2005
For all the Power FC users:
found this thread with free database maps with users uploading their maps, i guess you can find the setup similar to yours and there you have a free map. original thread is from Freshalloy.com so i copied the OP's post into my own thread. http://zilvia.net/f/engine-tech/2486...base-free.html
#780 |
So mi done dealing with McKinney motorsports and JWT. I'm going to Canyon Racer Motorsports for my rebuild and Steve for my tune.
My mods are: GT2871r .64 740cc TOMEI injectors Megan Ex. Mani (going back to stock) BC 264/264 cams JWT tune and some other minor things. Michael said that he can do the rebuild and he seems like a really great guy. more for the love of it kind of person. I hope do to with 9.0:1 compression pistons this time with a full rebuild head and block (replacing whatever is worn) and for a tune im going with Power FC L-Jetro for Kouki S14 SR and it will be tunes by the hands of Steve!! muahahaha...i came back from iraq and my car turned to shit! but this time I will go to the right shop that wont miss anything and will put everything they have into my motor. I'm not sure what i can get on a DynoDynamics dynometer but i will post up once things are done.
want to be in the 500whp club by the end of next year!!! |
