![]() Join Date: Apr 2008
heelp !!!
jus got finishin rebuilding my kade a few days ago..just got it 2 start and run but it doesnt seem like it gettiin oil pressure..how do i check it other than takin the front cover off again"??this really sucks cuz it sounds soooo mean runnin.. but it ran for a lil and shut right off like it had a vac leak or no maf..heeeeeeeeeeeeeeeeeeeeeeelllllllllllllllpppppp pppp!!!!!!!!
LAID OUT
![]() Join Date: Mar 2004
do you have an oil pressure gauge? What makes you suspect the oil pressure?
To start with, Pull the codes from the ECU. Then go inspect all your wiring/connections, vac hoses and base timing. Start with the easy/simple stuff... Then post more symptoms |
