Closed Thread
Old 08-12-2014, 10:31 AM   #1
demi.colwell
demi.colwell's Avatar
demi.colwell is an unknown quantity at this point
Gt2871r turbo questions
I believe it's a Gt2871r I am getting. It's Gt28 something r but anyway I have a red top sr20det in my s13. My t25 took a dump on me so I figure I might as well upgrade. The guy im buying this turbo from said the stock Sr20 fuel system can handle 16 psi without a tune. Is there anyone to verify this? I would assume it would probably be more like half that to run relatively safe. At the moment I do have a 3 inch turbo back exhaust front mount intercooler and a walboro 255 fuel pump. My injectors are unknown so I'm going to say it's stock. I won't really have a lot of time to test with the turbo coming in Friday and I will be getting it on Saturday with a race I'm hoping to go to Sunday.
demi.colwell is offline
Old 08-12-2014, 10:51 AM   #2
jamg
jamg is an unknown quantity at this point
you'll need upgraded injectors to run 16lbs.
550's minimum.
jamg is offline
Old 08-12-2014, 03:20 PM   #3
demi.colwell
That's what I kind of figured. What would be a safe boost level while assuming I have stock injectors and no tune? This turbo comes with 13.5 psi on it from what I was told but it can be adjusted down. So is it safe to take it out for a quick run see what happens and make my adjustments or is over boosting something that could just basically rip my engine apart within a few seconds?
Old 08-13-2014, 04:46 PM   #4
Future240
Future240's Avatar
http://zilvia.net/f/showthread.php?t=124925
An entire thread dedicated to this turbo.
Originally Posted by ThatGuy
Future240 is offline
Closed Thread
