Old 11-30-2009, 05:43 PM   #1
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
1996 240SX USDM F4 pinout
White plug near the ECU. 12-pin.
1 Blue/Red ABS Warning Light, ABS only (BR-32)
2 Blue/Green DT1 connection between auto ECU and engine ECU (EC-230)
3 Blue/White DT2 connection between auto ECU and engine ECU (EC-230)
4 Blue/Red DT3 connetion between auto ECU and engine ECU (EC-230)
5 Red/Green Neutral Position Sensor connection to auto ECU (EC-235)
6 Blue/Green Idle Switch from Throttle Position Switch, auto only (AT-36)
7 Red WOT switch from Throttle Position Switch, auto only (AT-36)
8 Yellow power to Throttle Position Sensor, auto only (AT-40)
9 Red/Black A/T Diagnostic Communication line, auto only (EC-282)
10 Red/Yellow TH/SEN (IN) pin of auto ECU from TV00 pin of engine ECU, auto only (AT-39)
11 Black Sensor Ground, used to ground the Absolute Pressure Sensor Ground (EC-113), Intake Air Temperature Sensor (EC-119), Engine Coolant Temperature Sensor (EC-123, 133), Throttle Position Sensor (EC-128), Crankshaft Position Sensor (EC-170, 251), EGR Temperature Sensor (EC-181, 260), auto only
12 Green/Yellow 10A switched ignition power to ABS actuator, ABS only (BR-33)
g6civcx is offline   Reply With Quote
