Old 03-27-2014, 11:13 PM   #1
kouki98
kouki98 is an unknown quantity at this point
help please!!!!
Ok so hopfully my fellow zilvians can help me out of a bind.
So here it goes So my 98 s14 has decided to do throw a CEL code p0100 maf circuit malfunction. My car now ramdomly bucks/ hesitates when at a constant speed or above
3k rpms. I have cleaned my maf,and cleaned the plugs and checked the harness and they all seem fine. Any ideas or suggestions would be greatly appreciated.
Info:1998 240sx
128, xxx mi
Bone stock motor
kouki98 is offline   Reply With Quote
Old 03-27-2014, 11:14 PM   #2
sidewayzzenki
sidewayzzenki is an unknown quantity at this point
Wow shes a baby..ha
sidewayzzenki is offline   Reply With Quote
Old 03-28-2014, 03:38 AM   #3
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Check your plug, make sure its plugged in all the way. Also check the wires to the plug, hopefully nothing is frayed or broken.
eek is offline   Reply With Quote
Old 03-28-2014, 09:18 AM   #4
kouki98
I'll check it out today. Thanks
Old 03-28-2014, 10:08 AM   #5
Roki187
Roki187's Avatar
Roki187 is an unknown quantity at this point
U need a new or referb mass air flow sensor.
Roki187 is offline   Reply With Quote
Old 03-28-2014, 10:47 AM   #6
SuperBlackS14
SuperBlackS14's Avatar
SuperBlackS14 is an unknown quantity at this point
I had this same issue... Check the wires going to the maf. Mine had the 3rd wire (red?) broken. Simple solder fixed it right up.
Also... Small Questions Thread next time perhaps?
"Power Is Nothing Without Control"
SuperBlackS14 is offline   Reply With Quote
