Old 08-22-2011, 12:43 PM   #1
Mirage
Mirage is making a name for him/her selfMirage is making a name for him/her self
Send a message via AIM to Mirage
S14 SR20 Part out + lots of aftermarket 2871R, Apex'i, Tomei, Blitz, Toda + lots more
Have most everything pulled out now, getting ready for VH45 Swap, only trade i'm interested in is low mileage '94-95 VH45 or Z32 TT 5 speed. Will ship at buyers expense most everything. Have original boxes for most of the parts. Can get more pics if needed.
Zenki S14 SR20DET Apex'i PowerFC L-jetro w/ commander - $700
Take both PowerFC and Boost control kit for $800+shipping
Apex'i Boost Control Kit for above - $175
Kazama solid engine mounts - $150
Nismo tranny mount - $30
Take both for $160 + shipping
http://img851.imageshack.us/img851/9...1082200096.jpg
Toda S13/S14 SR 10.5 lb Chromoly flywheel, still in great shape - $375
SR RPS Max clutch with street disc, disc has a little life left in it, replacement from RPS is $115, holds up to 475 ft/lbs - $150 ($125 for just the PP)
S14 VTC solenoid, used an infiniti part number to get this, little over a year old - $65
Got another Z32 MAF with pigtail - $75
Turbo lines are aeroquip startlite hose (Kevlar/Nomex braid) and hose ends, techna-fit metric banjo fittings, restrictor fitting and turbo fittings, and one russells metric adapter, and ATP turbo drain fitting/hose. Tomei Manifold, Elbow, 2871R in the pictures are SOLD.
Turbo lines - $135
Stock S14 SR PS pump, starter, and CAS
PS pump - $50 add $20 for bracket and tensioner
CAS - $125
Starter - $75
Belts if somebody needs them AC is sitting unused in my room, alt and ps are in good shape still, OEM nissan couple years old - $25 for all 3.
S14 SR transmission, was shifting good, have been using mt-90 in it - $150
Real C's short shifter, works on both KA/SR transmissions, back to being hard to find - SOLD
Old KOYO S14 KA aluminum radiator, decent shape - SOLD
Flex a lite 210 e-fans SOLD SOLD SOLD
S13/S14 coil packs, less than 3 months of actual use on them - SOLD
HKS SSQV black limited edition, about 1 month run time - SOLD
Z32 MAF (bought brand new from Nissan ~2 years ago), Apex'i bolt on filter (no adapter needed), aluminum 45*, Samco couplers and t-bolt clamps. Works well with stock style turbo setups. - SOLD
Blitz SR stainless downpipe with wideband bung welded in, no dents or scrapes, little dirty. SOLD
Unknown IC core, pretty good quality, weights a ton, core is ~24x12x3, cobbled together S14 SR piping from previous owner, replaced all the couples with samco's and t-bolts, has an hks flange on the cold pipe - SOLD
Also have an old school S14 RS-R Exmag, full stainless muffler, looks like 409SS piping, no dents, couple of light scrapes. Local pick up only on this - SOLD
Mirage is offline   Reply With Quote
Old 08-22-2011, 07:00 PM   #2
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
PMed for Oil pan and turbo lines.
Luvs2slide is offline   Reply With Quote
Old 08-22-2011, 11:25 PM   #3
Tkwjh07
Tkwjh07 is an unknown quantity at this point
is that a working alternator?
Tkwjh07 is offline   Reply With Quote
Old 08-23-2011, 08:49 AM   #4
Mirage
yep, alternator works, as does everything else listed.
Old 08-24-2011, 09:18 AM   #5
Mirage
few more things
S15/S14 Brand new oil pump/front cover (s15 part number, Ray at west covina claims it works with s14) goes for $155 from them, how about $140
S14 SR o2 sensor, fairly new - $40
Old 08-24-2011, 07:59 PM   #6
S14Lee
S14Lee is an unknown quantity at this point
Interested in the starter and alternator if u still have them
S14Lee is offline   Reply With Quote
Old 08-24-2011, 09:03 PM   #7
Ben10
Ben10 is an unknown quantity at this point
hey man interested in the MAF setup PM me a price shipped to 77058
you had it on a s14 sr correct?
thanks!
Ben10 is offline   Reply With Quote
Old 08-25-2011, 10:06 PM   #8
Mirage
midnight bump
Old 08-26-2011, 08:49 PM   #9
nickkaplz
nickkaplz's Avatar
nickkaplz is an unknown quantity at this point
how much for the injectors to 35007?
nickkaplz is offline   Reply With Quote
Old 08-26-2011, 09:39 PM   #10
theboy
theboy is an unknown quantity at this point
$30 shipped for the power steering pump bracket/tensioner/bolts?
pm me your paypal info if so
theboy is offline   Reply With Quote
Old 08-30-2011, 08:42 AM   #11
Mirage
fixed and some edits, and a final bump.
Old 08-31-2011, 07:37 AM   #12
S13nEG8
S13nEG8 is an unknown quantity at this point
Im in Summerville SC do you still still have the SR Tranny and if you do would you be willing to meet in Columbia?
S13nEG8 is offline   Reply With Quote
Old 08-31-2011, 10:50 AM   #13
darkdrifter95
darkdrifter95 is an unknown quantity at this point
how much for the koyo rad ship to 92507??
darkdrifter95 is offline   Reply With Quote
Old 08-31-2011, 11:11 AM   #14
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Send a message via ICQ to EDacIouSX Send a message via AIM to EDacIouSX Send a message via MSN to EDacIouSX Send a message via Yahoo to EDacIouSX
do you have better pictures of the valve cover? Please pm me. thank yuo.
EDacIouSX is offline   Reply With Quote
Old 08-31-2011, 03:05 PM   #15
darkdrifter95
ok cool..send me the info to pay.... how is that crossover hose??
Old 09-01-2011, 01:21 AM   #16
darkdrifter95
ok..thanks for the hose.. ill send the paypal tomorrow as soon as I get off work!!!
Old 09-02-2011, 12:20 PM   #17
Bernie (NoVA)
Bernie (NoVA)'s Avatar
Trader Rating: (357)
Feedback Score: 357 reviews
PayPal for injectors sent.
Bernie (NoVA) is offline   Reply With Quote
Old 09-03-2011, 08:48 PM   #18
Mirage
parts shipped, pms replied, and original post cleaned up and added package pricing for some of the parts.
Old 09-03-2011, 11:21 PM   #19
satal95
satal95's Avatar
Trader Rating: (24)
satal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud of
Feedback Score: 24 reviews
Selling the turbo manifold separately? If so how much shipped to 78237
Signature image exceeds allowable size.
satal95 is offline   Reply With Quote
Old 09-03-2011, 11:40 PM   #20
stealthsr20
stealthsr20's Avatar
stealthsr20 is an unknown quantity at this point
How much for entire turbo setup manifold to elbow shipped to 7406pm me please!
stealthsr20 is offline   Reply With Quote
Old 09-04-2011, 05:09 AM   #21
Mirage
Tomei Manifold has already been sold.
Old 09-08-2011, 08:31 AM   #22
XtremeS14
XtremeS14 is an unknown quantity at this point
Send a message via AIM to XtremeS14
pm'ed you about the cas and coil packs.
XtremeS14 is offline   Reply With Quote
Old 09-08-2011, 10:10 PM   #23
Bernie (NoVA)
Injectors arrived.
Thanks.
GLWS
Old 09-17-2011, 08:30 AM   #24
Mirage
All PM's replied to, was at the beach on vacation all week and only had my phone with spotty coverage, so sorry to everyone that didn't get an immediate response. Back to normal schedule now.
Old 10-15-2011, 08:38 PM   #25
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
mirage is legit! very good guy! valve cover got damaged in mail, so he worked shit out! thanks again man!
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 10-24-2011, 09:53 PM   #26
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
quoted for truth, mirage also sent me parts I needed in a bind and shipped right away. Great seller.
rancid240 is offline   Reply With Quote
Old 11-01-2011, 08:51 AM   #27
Mirage
bumpity bump
